Navigation & Audio Splitting the 6x9 Wires for Subs
Old Aug 5, 2008 | 09:10 PM
n_wong89's Avatar
n_wong89
Does anyone have tips on splitting the 6x9 wires to give signal to the amp for the trunk located subwoofers?
Do some people forget about the 6x9's or how do you go about wiring both the 6x9's and the subwoofers. Tips please!
(07' R56 MCS)
Old Aug 5, 2008 | 09:23 PM
ScottRiqui's Avatar
ScottRiqui
If the amplifier has speaker-level inputs, all you have to do is tap into the four rear speaker wires (R+, R-, L+, L-) and connect them to the amp.
Since you'll be installing subwoofers, you might want to install high-pass filters on your interior speakers so that they're not trying to play the low bass notes (since you'll have the subs for that). Look up "Bass Blockers" on www.crutchfield.com to find out more, but they're simple passive crossovers that you install in-line with your interior speakers.
Old Aug 6, 2008 | 05:23 AM
schatzy62's Avatar
schatzy62
Please read thru the threads there are a fair number of threads that deal with this issue and will probably answer all you questions.
Old Aug 6, 2008 | 12:53 PM
Robin Casady's Avatar
Robin Casady
The 6x9 speakers don't get full bass. I think it is cut off below something like 80 when it should go well below 10. I think you need to find another place to tap into for a sub.
Old Aug 6, 2008 | 03:24 PM
n_wong89's Avatar
n_wong89
Well i have read the line out converter has poor sound. It seems like most Subwoofer set ups, people have been using the 6x9 speakers. Any reccomendations on anything else?
I just want some thump! Haha
Old Aug 9, 2008 | 10:22 PM
k6rtm's Avatar
k6rtm
I just posted my test results, measuring the degree of suck in the rear channels.
Robin, you might find them interesting! Your comments in other threads got me to do this testing.
Quick summary: With the response at 2KHz as a reference, the rear level signal is down 3dB at 100 Hz, and down 30dB at 20Hz!
You aren't going to connect a sub to that, at least not if you want it to do anything!
You'll need to connect to the front speakers.
Old Aug 9, 2008 | 10:31 PM
ScottRiqui's Avatar
ScottRiqui
For the non-engineering types, a 3 dB attenuation means that the signal at 100 Hz has only one-half the power as the signal at 2 kHz.
The 30 dB attenuation at 20 Hz means that the signal only has one-thousandth of the power that it did at 2 kHz (in other words, by the time you get down to 20 Hz, virtually no signal is making it to the speaker at all.)
Old Aug 10, 2008 | 08:51 PM
n_wong89's Avatar
n_wong89
so where do you guys think the best place to get signal for my subs is? and how do i go about getting that signal? (if you know instructions and what not)
Old Aug 12, 2008 | 10:44 AM
k6rtm's Avatar
k6rtm
From what's going on in other threads, it looks like our best candidate for picking up good speaker signals (or at least as good as they get) is the X9331 connector, which is located ahead of the driver's door.
Follow the action in the "Frequency Response" thread to see how this one develops, but it looks pretty promising.
Old Aug 12, 2008 | 03:37 PM
n_wong89's Avatar
n_wong89
Yeah ive heard those are to be the best signals. But what if i went to the stock amp, and took out the input for those speakers and put them into my new amp. (the output being my new subs).
or tapping into them...would that be even better?
gar56
Nov 15, 2016 06:41 AM
shadtree
Cooper (non S)
Sep 8, 2016 12:02 PM
pkillur
Sep 30, 2015 10:51 AM
Samhillrocks
Sep 29, 2015 12:55 PM
dragonby
Sep 25, 2015 08:10 PM
