Navigation & Audio Bluetooth mic volume increase?
Is there any way to increase the volume for the mic so that people on the other end can hear me better? That is the most common complaint I hear when using this "I can't hear you very well...."
Not sure which side the microphone is on the clubman's, but US cooper owners have moved their's from the passenger to the driver side.
https://www.northamericanmotoring.co...oth+microphone
Yup, moving the microphone makes an incredible amount of difference! For some Bavarian reason, the microphone points at the passenger! It takes about five minutes to move it to the driver's side.
Pop off the cover plate, and you'll see the microphone -- rectangular thing with a wire off the back, on the right side. It wants to be on the left side!
Moving the microphone is easy; moving the damn wire is the hard part -- I have a good assortment of tools, so I pulled the panel out (two torx screws? Might have been phillips, but I think they were torx), moved the wire, and reassembled. Sounds much better!
Also check the volume on your phone. I have an iphone and it took me a few rounds with my MC's Bluetooth controls before I realized that the separate Bluetooth volume on my phone was all the way down. Once I changed that, I had people telling me my mic was too loud!
I'm sure it varies phone to phone, but maybe try turning on the volume on the phone itself up while you are on a call?
I did the MIC Switch from Passenger to Driver's side. In fact I asked the MA to have it done when car was prepped for delivery. And suggested he do it on all cars. He said he planned to.
But here is the issue. The blackberry is synced and works fine. Out bound voice is fine. Inbound volume is very low. The Blackberry says "Bluetooth Volume set to Low". But Verizon says Bluetooth Volume can't be adjusted on the phone. Does that make sense?
Is there something in setup to adjust the inbound voice volume? Turning the volume switch on the radio didn't seem to have any effect.
Thanks, Finner
Thanks, Finner
If this dow not wokr come back and let me know and i will try to help you with other remote posibilities
On my BB Curve from sprint (same as Curve from Verizon 8330), when connected to BT in my 08 MCS, volume is automatically set at "middle" I do want to increase the volume and cannot adjust. I had my radio volume **** all the way to the right
BTW, i did the channel swap of my speakers. BT only comes from the back since channels are swapped. Since the rear speakers are worse than 1990 OEM Civic speakers, the sound becomes all buffled. I may just swap the channels back but i will lose the little thump thump sound...
My 4runner has better speakers than this POS speakers.
That may be but the volume will only adjust while the other party is speaking. So have someone call you and repeat a sentence a few times while you rotate the volume control. If the other end is not speaking the volume does not change if the control is rotated. Strange how it works that way but that is what they do.
We noticed that if there is any pause as the other person speaks the volume doesn't adjust. But as Shatz states, have someone continuously speak and you will definately be able to increase the volume and hear better. Worked for me!
Thanks Schatzy!
....Finner
Thanks Schatzy!
....Finner
Bonehead,
Who knows why! I just followed advice given by Schatzy and it worked. When someone is speaking, I can adjust the volume up or down. If they are on the line but silent, adjusting the volume seemed to do nothing. I wasn't concerned about why...I was just glad to get the issue resolved.
And that is jsut the way it works on BMW's and MINI's
Ha, this is the biggest complaint I've had with my car, 2nd to the terrible OEM speakers.
This forum is awesome
I'm doing that swap of the mic today.
Schatzy you have provided a lot of us with some great information about our cars and mods we can do to improve things. Thanks again for being valuable contributor
I also find that with the fan on anything above the lowest setting, there is wind-noise interrference form the dash-top vent. Whenever my wife calls from her Clubman and I can't hear well, I remind her to turn the fan down.
Not sure which heating control system you have but i have the fully automatic climate controls and never have wind noise from the dash center vent until i take it off automatic and send all the venting to the windshield. Even at that no one has complained about the sound or lack of quality.
Have you moved the Microphone yet? It comes from teh factory with it mounted on the passenger side. That makes a very very very large difference as well.
I swaped the mic today and it does seem to help quite a bit. I want to spend some time trying to tweak levels from the phone. I think the problem I run into is that because I am tall, I sit quite a ways from the mic. It seems to be very sensitive to the difference because when I drive with the kids (and I sit farther forward) my wife doesn't seem to have the same issues hearing me on my phone.
Jim Ferrell
Oct 6, 2015 08:09 AM
Tires, Wheels & Brakes
Oct 1, 2015 02:22 PM
Oct 1, 2015 12:18 PM
