Navigation & Audio 07 stock sound system speakers?
Old Feb 9, 2008 | 08:20 AM
dr quest's Avatar
dr quest
Question should I replace the stock speakers with a set of component speakers (Pioneer TS-A1702C).
Or should I repleace the stock speakers 6.5 and 3.5 with better speakers of the same size?
Also does the stock sytem use a crossover in the front speakers.
Old Feb 9, 2008 | 11:45 AM
Robin Casady's Avatar
Robin Casady
I think that a component speaker is a good choice for 6.5" spot because it is where the bass goes. No point in having a built-in tweeter in that speaker.
Seems to me that replacing the 3.5 (actually I put a 4" there because the 3.5" speaker was too small) with just a tweeter would lose a lot of the mid-range. You would then only have the rear 6x9s for mid-range, and you don't say anything about replacing them. However, a number of people have replaced the 3.5 with a tweeter and seem to like it.
Old Feb 9, 2008 | 12:00 PM
matty125's Avatar
matty125
what ever you replace them with, you better pull the door panel off first to see what you got, 3.5 in speakers will not fit in the holes, aim closer to a 4 in.
If you really want 3.5 i have a brand new set I couldnt return.....I trusted some peoples measurements and they are completely wrong.
ANY Aftermarket speaker will be a huge improvement from the stock garbage.
Old Feb 9, 2008 | 02:04 PM
dr quest's Avatar
dr quest
sub in the rear
That's what I was thinking.
What dp you think about replacing the woofer and leaving the stock 3.5's (or what ever they are) and adding the tweeter from the component set. Do you think i have enough power to drive all those speakers without adding an amp?
I have good base from a power sub woofer i added in the rear last week.
Old Feb 9, 2008 | 02:06 PM
dr quest's Avatar
dr quest
i don't really want 3.5's, i was told that is what the stock size is so i thought it would be a easy swap.
what kind you you have and how much?
Old Feb 9, 2008 | 05:03 PM
Robin Casady
I have the HIFI option, so I used 2 ohm Infinity Kappas. You need 4 ohm.
One thing to watch out for is speaker sensitivity. If you just swap the 6.5, and leave the 4" as stock, the 4" may be a lot louder than the new 6.5. The Pioneer TS-A1702C only have a sensitivity rating of 90 db. My Kappas are around 95 db and are not as sensitive as the stock speakers seemed to be.
It might be best to go with a particular line of speakers and stick with them, so they are voice matched.
Old Feb 9, 2008 | 06:34 PM
dr quest's Avatar
dr quest
so you saying not to use the stock 4" and just use the new 6.5 and tweeter combo?
Old Feb 9, 2008 | 07:57 PM
donuttang's Avatar
donuttang
any folks has the direct replacement speaker choose for the front door? i mean directly fit in the door panel for a stock 07 MCS with no hifi option..
brand
model
cost
quality
i really think of changing it but afraid of hassle of modification...
thanks
Old Feb 10, 2008 | 12:02 AM
MotorMouth's Avatar
MotorMouth
If you replace them with a 2 piece component system you shouldn't lose any midrange. If you took the mid out of a 3 way then you'd lose.
You should be able to replace the 3.5 with a tweeter from a 2-way with no problem.
If you aren't adding an amp get something with high sensitivity.
surfblue
Oct 24, 2018 01:20 AM
theblackfalcon
Oct 11, 2015 09:49 AM
jnrjr79
Navigation/Audio
18
Sep 18, 2015 05:51 AM
Powershift
Aug 16, 2015 05:14 PM
