Navigation & Audio How to: move the Bluetooth microphone
I have done this to my clubman s and it helps...a bit. The bigger problem is the fan. On a hot day, you have a choice: turn the fan off and boil, or sound like you're in a wind tunnel.
To test it.... Call yourself and leave yourself a voicemail , and turn the fan from off to full while counting from 1 to 10.
I haven't designed an elegant "wind shield" yet
I'm with you... Moved mine and it only helped a bit. Disappointing, I would love to be able to use this all the time. So annoying when you have the phone plugged in to unplug and change the audio source. Not to mention trying to hold the phone, drive and change gears.
Did this last night. Didn't help. Called my wife, and sounded fine when I wasn't moving. The minute I start moving, she said it sounded like wind tunnel. It's not even that loud inside the car! What gives! It's like the opposite of noise canceling. Awesome a NOISE ENHANCING microphone!
What are the options for replacing the mic with a better one? I saw a BMW thread where they were talking about replacing the mic with an upgraded noise canceling one
Dual Mics
I'd LOVE to find a cable that had a female plug that took the male part that plugs into the mic, and goes to 2 male plugs. That way you could use 2 mics, 1 on each side. Anybody know where I could get a extra mic ?? Not sure where I could get a plug to go by, so I could get a female plug, but would love to give this a shot !! Any ideas anyone ?? I'd but a extra mic if anybody knows where to get 1 at a fair price or has 1 for sale. Anyvody know what kind of plue that is on the end of the wire ??
2011 MCS Ice Blue Auto
2005 MCS Yellow 6 speed
For those of you subscribed to this thread, but still not happy... try Drew's new method over on this thread:-
https://www.northamericanmotoring.co...bluetooth.html
1. it would cause worse sound to the person on the other end as the two mics would be picking up the sound at two very slightly different times and thus causing the same sound to be transmitted twice at slightly different times.
2. adding a second mic would change the impedance the ULF module sees from the microphone and thus causing distortion of the sound before it get transmitted. Again making the sound worse than what it already is.
BTW mine works great I have been on the other end of the conversation when the gf is using my car and it sounds as good if not better than when using the phone by itself.
Moving the mic to a different location will affect how it sounds but could also make the clarity worse by affecting the way the mic and amplifier work together before the sound is transmitted back to the phone.
Also of note is that many phones have a separate bluetooth volume and if changed can make the sound quality much better. iPhone are notorious for having this problem as the signal from the mini is sent to the phone and the phone amplifies or reduces the amplification and causes distortion of the sound, thus causing the quality to be greatly reduced.
Microphone wire location?
I'm looking to add an aftermarket radio (actually already done this part) that has space to plug in a Mic to use over bluetooth.
Question is this. Where does the wire end up from the Mic? My friend's car has the Mic (and in the wrong location, as you all note), but I need to splice it into the Mic cable that came with the radio to use it instead of the Mic that came with the radio.
Thoughts?
Thanks!!! Know this is a very old thread. Hopefully folks are still following.
Lordloki
Thoughts?
Lordloki
Your best bet is to use the microphone that came with the radio rather than try to use the MINI Microphone. I know a few others have tried to use the MINI Mic and they have some strange parameters that do not match what most aftermarket radios use, so they really can sound horrible.
The mic that came with your radio is matched specifically to that particular radio unit so that would be the best sounding.
Thoughts?
Lordloki
Thoughts?
Lordloki
Hi, I have had problems with outgoing sound quality on my 'British' 2008 MCS. When I read this post and looked in the housing I found that my car had the mike on the 'American' side. Swapped it round but then thought that while I have the access I'll pad out the area with some sound deadening material, so I did. I'm hoping that this will reduce any echo from the rather large cavity above the mirror. I'll give it a test later on today to check out any improvement, only bad thing is I won't know if any improvement came from the mike move or sound proofing or both.... Ah well, the joys of tinkering! Thanks for the write up, made it all really simple, just wish I'd seen it 18 months ago!
Follow up report:
Much better now but it still drops quality occasionally. I'll live with it.
2008 astro black MCS, custom nav, leather, climate, coded comfort closing windows, digital speed always on
Follow up report:
gar56
Nov 15, 2016 06:41 AM
Pedro99
Oct 3, 2015 10:56 AM
MINI Stupor
Oct 1, 2015 11:36 AM
