Navigation & Audio R56 Hi-Fi with Infinity Basslink
Old Dec 8, 2007 | 07:42 AM
fitzgerb's Avatar
fitzgerb
I have a non S 2007 cooper R56 with the HIFI. I want to add a powered sub such as the basslink. My concern is the quality of sound from the sub by installing via the rear speaker inputs. I am apprehensive to the quality by this method, and I looking for some specific feedback by owners who have such a set up with a powered sub. I have had a powered sub on an aftermarket head unit and it sounded incredible. I want that same experience in my mini.
I am aware there are other posts and I have searched using the search button and have not come up with any real answers. Thanks for your time
Old Dec 8, 2007 | 09:52 AM
Robin Casady's Avatar
Robin Casady
The rear speakers get very little bass. I think it is filtered before it gets to the rear amp, but I'm not sure.
Old Dec 8, 2007 | 10:23 AM
MotorMouth's Avatar
MotorMouth
since you have the hifi you have all the speaker wires you need to access in the left side of the boot. Read the sticky to find out which wires are the input to the amp for the front speakers. I don't know if you'd want to tap the output of the amp.
Old Dec 8, 2007 | 04:16 PM
fitzgerb's Avatar
fitzgerb
What's "the sticky"? Im assuming its a previous post or a specific post. By the way, thank you for your information. It is so great to have access to such a broad pool of knowledge about the R56. Mililani? I used to live in Aiea for about 4 years.
Thanks again
Old Dec 8, 2007 | 04:39 PM
Robin Casady
Sticky posts are ones that stick to the top of the forum. Speaker Replacement is the one you want.
https://www.northamericanmotoring.co...ad.php?t=95211
Old Dec 8, 2007 | 07:23 PM
fitzgerb's Avatar
fitzgerb
I have read the speaker replacement post and its a big fat mess. Its very scattered and I cannot find an answer to this question: If the bass of the rear speakers is poor, then should I tap only the front speakers, or both the front and rear? The basslink has the availability to use 4 speakers as line sources. I would love to hear from someone who has the basslink in an R56 HIFI, and to know how it was installed, how it sounds, and their level of satisfaction. Is a Mini cooper like the hardest car on the market to upgrade the audio?
Old Dec 8, 2007 | 09:40 PM
Robin Casady
Well, the rears don't get much bass, so what's the point in using them? All the bass goes to the largest speaker in the door.
I don't know whether the MINI is the hardest, but it is odd and you can void warranty and damage some very expensive electronics if you do the wrong thing to the amp.
Old Dec 10, 2007 | 08:44 AM
Birdman's Avatar
Birdman
Simply tap into the Amps (in the boot) FRONT speaker inputs, and run them to you Basslink. That will sound lovely, and is very easy to do.
Good luck.
Old Dec 10, 2007 | 09:45 AM
fitzgerb's Avatar
fitzgerb
Thanks Birdman! That sounds so easy and straight forward. This setup seems like such an easy fix for a sub par HIFI system. For a few hundred dollars you can just add bass and then your good to go. Im assuming you just turn down the bass on the head unit and turn up the gain on the sub? I am a big fan of the basslink and I dont think you can get more bang for your buck. The only issue: how difficult is it going to be to run a power cable from the battery? Another question: there are many posts referring to a voided warranty by upgrading the audio and potentially damaging the system. What are your thoughts about that?
Old Dec 10, 2007 | 11:15 AM
Birdman's Avatar
Birdman
If you just attach wires to the speaker inputs before the amp, nothing will be void, don't worry about it. They are talking about making big changes...
Running a power wire from battery is easy, there is a port to get thru the firewall right behind the battey, come down the kick panel and then run it across the door sill. Piece of cake.
And I agree, the problem with the hifi is mainly lack of BASS. But they also should be using better speaker than paper.
Old Dec 10, 2007 | 11:27 AM
Bor's Avatar
Bor
should be even easier for the power wire - don't we have a 12V plug in the boot ? (that's how I connected my Basslink in my R50, haven't had the time to check and connect it in my new R56)
Old Dec 10, 2007 | 11:41 AM
MotorMouth's Avatar
MotorMouth
I'm surpised you haven't blown the fuse for the 12v outlet yet.
The wire feeding that thing is TINY compared to what you should be using for an amp.
Old Dec 10, 2007 | 01:41 PM
Birdman's Avatar
Birdman
Yea, you should use something heavier than the little 5 amp'er in the "lung killer" connector.
Run a new wire. you'll get better bass out of a heaveir run also.
Old Dec 11, 2007 | 12:28 PM
Bor's Avatar
Bor
good to know, thanks, glad I haven't done this on my r56 yet
Old Dec 11, 2007 | 07:17 PM
rkw's Avatar
rkw
The fuse is actually 15A, which isn't bad (same value as the fuse for the entire OEM audio system). They did intend the cigarette lighter to be capable of handling most things that people might want to plug in. What you'd give up is that it won't have power when the ignition is completely off (such as listening to the system in a parked car without using the key).
Old Dec 11, 2007 | 07:25 PM
MotorMouth's Avatar
MotorMouth
I've never seen an amp with a cigarette lighter adapter on its power cord.
Go ahead and use it if you want a ghetto install.
Old Dec 12, 2007 | 09:00 AM
fitzgerb's Avatar
fitzgerb
So what is the suggested gauge of wire to use and where does one obtain said wire. Radio shack has a weak selection of lower gauge wires.
Old Dec 12, 2007 | 09:18 AM
Minidrivr's Avatar
Minidrivr
The fuse that runs both front/rear cig lighter outlets in my car is a 20 Amp.
Old Dec 12, 2007 | 09:33 AM
Birdman's Avatar
Birdman
hmmm, 15 huh? wow, that's pretty high. I thought I saw 5 in the manual. Have to check later. Either way though, I would run a new line anyway direct to the battery, with a fuse at the battery, using 10 guage wires.
Old Dec 12, 2007 | 12:15 PM
MotorMouth's Avatar
MotorMouth
Look in the owners manual for the amp to see what size it recommends.
I personally use a minimum 8ga or bigger.
Most high quality amps will accept 8 ga or bigger.
The two factors are how much current the amp draws and how long the wire needs to be.
For your power and ground wire, bigger is always better.
Old Dec 12, 2007 | 02:06 PM
Birdman's Avatar
Birdman
I'm with ya brother.
But the basslink (and other smal powered subs) only put out around 100 or 150 watts. They ussually call for 12 or 14 guage in the manuals believe it or not.
rtk90
Aug 29, 2019 09:08 AM
newowner
Sep 15, 2015 07:18 AM
Colt45Magnus
Sep 14, 2015 03:12 AM
