Navigation & Audio New speakers?
Old May 28, 2007 | 07:22 PM
Mgibrace's Avatar
Mgibrace
New speakers?
How has your experience been if you've replaced your speakers? Fronts/rears/standard or hifi upgrade radio. MY MCS is due mid-late July and am very interested what your results have been.
Thanks for any feedback you feel like sharing.
Mark
Old May 29, 2007 | 04:54 AM
DyeLooper's Avatar
DyeLooper
I replaced all spkrs so far except front pillars, that will be soon. The biggest improvement came swapping out the 6 x 9's/rear tweeters IMO.The 6 x 9's were cheap. The front speakers were alot better quality although cheap compared to the 6 x 9.
Old May 29, 2007 | 06:45 AM
Paul's Avatar
Paul
Std speakers are pure crap. I'm waiting to see what BSW releases.
Old May 29, 2007 | 06:54 AM
Loony2N's Avatar
Loony2N
I agree with Paul. I have the upgraded HIFI and the speakers don't cut it. I'm planning to wait a while and see what mods work out for others. If anyone has any experience changing the speakers in the A pillars, I'd like to hear about it.
Old Jun 5, 2007 | 08:39 AM
Birdman's Avatar
Birdman
What did you replace the 6x9's with? Is it just a pop-in replacement with another (better quality) 6x9?
Old Jun 5, 2007 | 02:08 PM
MotorMouth's Avatar
MotorMouth
Replaced my hifi speakers with focals and the sound was much better.
Then I added an amp. Holy Crap!
Old Jun 5, 2007 | 05:28 PM
DyeLooper's Avatar
DyeLooper
I put in Infinity kappa's, quick change out, do drilling required.
Old Jun 6, 2007 | 01:12 AM
Robin Casady's Avatar
Robin Casady
Was that supposed to read "...no drilling required" or "you have to do the drilling required."?
Old Jun 6, 2007 | 02:13 AM
02ChiliMINI's Avatar
02ChiliMINI
I recommend Crutchfield: www.crutchfield.com or (888) 955-6000.
They have really good interface that shows you all the speakers that will fit into your specific vehicle (Yr/Model/Options, etc). They also have specifically made installation kits, wiring harnesses, etc. Overall, they are a very informative and professional bunch of car audio nuts.
Good Luck!
Old Jun 6, 2007 | 09:36 AM
MotorMouth's Avatar
MotorMouth
Good Luck!
excpet they don't have the 07 MINI info yet.
Old Jun 6, 2007 | 10:24 AM
02ChiliMINI
Sorry, didn't catch that Mgibrace has an '07
They add new vehicles periodically, so it may be worthwhile checking in with them every couple of weeks, if you can wait . . .
Old Jun 7, 2007 | 07:36 PM
DyeLooper's Avatar
DyeLooper
I'm sorry, yes no drilling or cutting needed on the rears. I put 6 x 9 kappas in the back with Kappa 10.7t for the rear tweets on the back armrest. 6 1/2 & 4" infinity reference's in the front. I had to use a dremel and had to do a little manipulating to get the 4" in. Sounds EXCELLENT. See my gallery. Still need to do the front tweets. AM/FM stereo bass thumps, cd's and Ipod sound good, but dont have near the thump. Hope that helps.
Old Jun 8, 2007 | 01:31 AM
MotorMouth's Avatar
MotorMouth
am/fm thumps harder than a cd?!?
Old Jun 8, 2007 | 11:08 AM
familiarstranger's Avatar
familiarstranger
it appears the way the HU is set up it pumps more bass for Radio, and the CD, and lastly any auxillary. so i set my EQ on my ipod to send some more bass to keep it balanced.
Old Jun 8, 2007 | 08:19 PM
Birdman's Avatar
Birdman
Familiar,
Doesn't the "thump" under the seat help?
Old Jun 8, 2007 | 08:35 PM
EightFingers's Avatar
EightFingers
Focal are amazing arnt they, kappa perfects in the back. Resont Engineering SX12 in the trunk with a box from www.thecaraudiobox.com 2 alpine pdx's very small amazing amps.. the pully doesnt do anything for sound, but the pic is cool
Attached Thumbnails New speakers?-dsc00342.jpg   New speakers?-pully-install-5-.jpg
Old Jun 8, 2007 | 08:42 PM
DyeLooper's Avatar
DyeLooper
Whats the HU? Can this be changed?
Old Jun 9, 2007 | 09:37 AM
familiarstranger
haha birdman it helps alot, but If i switch from a cd to my ipod. I have to change my crossover and volume, so I just made the adjustments on my ipod so i wouldnt have to continue to fiddle. IM sorry the HU is the head unit and no it cannot be changed
Old Jun 10, 2007 | 05:20 AM
DyeLooper's Avatar
DyeLooper
dat suks!!
Old Jun 10, 2007 | 11:43 AM
Mgibrace's Avatar
Mgibrace
Everyone, thanks.
Dye, which references did you use for the fronts? I'm confused. You seemed to indicate you liked the references over the kappas. I've been out of car stereo for a while, but aren't the kappas more expensive than the references?
And yes, I'm an idiot. Is your car an 07?
Old Jun 10, 2007 | 11:45 AM
Mgibrace's Avatar
Mgibrace
motormouth, which focals?
Old Jun 10, 2007 | 05:19 PM
Nui's Avatar
Nui
I'm interested in upgrading my '07 as well. Since Crutchfield doesn't have the spec what are the speaker sizes and space requirements? Especially depth.
Old Jun 10, 2007 | 06:41 PM
DyeLooper's Avatar
DyeLooper
Originally Posted by Mgibrace
Everyone, thanks.
I like them both the same, although I would of liked the kappas all around. The reason I went with the ref for the fronts is because there is no room for the crossovers in the front. I thought about this afterwards, you could put the crossovers inside the door panel of the 6" openeing by using velcro. but I used the ref in the fronts, had there been room for the kappa crossx's in the front, I would have went with the kappas. I used the ref 6 1/2 Infinity Reference 6022i and for the 4" I used the Infinity Reference 4022i. The 4" I had to use a dremel to get them in. Hope this helps, yes 07'.
Old Jun 10, 2007 | 06:43 PM
DyeLooper's Avatar
DyeLooper
Depth on the 6 x 9's is pretty deep, if buying from crutchfield, you can always return them if they dont fit.
Old Jun 10, 2007 | 09:51 PM
Mgibrace's Avatar
Mgibrace
Dye, Thanks. Did you get the factory covers back on? I'm partial to the stealth look.
