MTH Discussion (Archive) Have or interested in MTH software upgrades for your MINI? This is the place! Sponsored by MTH.
Cooper with MTH tunner - Plug change ?
Old May 6, 2006 | 10:54 AM
DeadEye's Avatar
DeadEye
I picked up some NGK plugs as part of an order a while back and they are the BKR7EIX plugs one range colder than the stock BKR6EIX would be ?
Will it run hotter with the 94 Octane maps ?
Will changing to the colder plug be *too* cold ?
I dont abuse it but i try to keep it in the power band ?
Advice appreciated from the guys that wrote it...
( i am also looking at adding the Header )
Old May 9, 2006 | 07:26 AM
DeadEye's Avatar
DeadEye
Bump...
no opinions...
( there in the car now - part of MINI 80K service...)
so well see... i'll drive a tank of gas and pull em out !
Old May 9, 2006 | 07:55 AM
DarkMiniCooperS's Avatar
DarkMiniCooperS
Usually, colder plugs are for engines that runs higher boost...
I really don't know if there are advantages for N/A engines.
Old May 9, 2006 | 08:42 AM
DeadEye's Avatar
DeadEye
94 Octane + MTH Tuner *load* ?
Will it run hotter ? ( was the answer i was waiting for from MTH )
But it never came...
Old May 13, 2006 | 08:53 PM
DeadEye's Avatar
DeadEye
Got the Dealer to use my plug for the Inspection II on Tuesday and have put over 300 miles since.
After the last little outing pulled into the garage. let it cool down and check the plugs clean - no foul... i'll keep checking them...
Old May 17, 2006 | 06:51 PM
rough68fish's Avatar
rough68fish
Cooler help stop detonation
I think that the cooler plugs help stop detonation by cooling the tip on the plug, which is usually the hot spot in the chamber.
Detonation can be caused by:
- Increased pressure from more boost, higher compression pistons decreased deck hight...
- Increased timing advance
- Higher temps
- lower octane fuel
On my older cars I work with the heat range of the plugs once I have the carb and timing dialed in so that I am using the coldest plug I can without fouling in normal driving conditions.
So I think the answer to your question is that they wont provide any additional power over a new set of the normal heat range but I don't think that most Mini's see driving conditions that will foul them out either but let us know how it goes.
Old Jun 11, 2006 | 09:41 PM
DeadEye's Avatar
DeadEye
2000 Km later and the plugs are Clean - no fouling ( black )
tr3y003
Oct 22, 2015 10:48 AM
sprp85
Aug 22, 2015 06:16 AM
dscott90000
Aug 21, 2015 07:07 PM
Minii cooper bean
Aug 11, 2015 02:10 PM
ludedude
Aug 10, 2015 07:16 PM
