Plastic strips under car.
Old May 19, 2003 | 09:18 PM
SB's Avatar
SB
I noticed some small strips of plastic attatched to the underside of the car and am not sure of the reason. There are 5 of them. Two I could understand maybe some type of protection from road debris for the gas tank but there are two in front of the rear tires also. Plus one in the center just behind the engine. Are these for protection? I'm just curious. :smile:
Old May 19, 2003 | 09:25 PM
SuperMINI03's Avatar
SuperMINI03
Hmmmmm, I never noticed that, good job, can't wait to find out.
Old May 19, 2003 | 09:34 PM
'*Ace*''s Avatar
'*Ace*'
I kinda ran over a divider once and kinda wore them down a little... ...I have no idea what they do or how to remove them though.
Old May 19, 2003 | 09:39 PM
vespa's Avatar
vespa
They're "curb-feelers"
Old May 19, 2003 | 09:41 PM
discodan's Avatar
discodan
i always thought they might be under car mud flaps. Saabs have had these under their cars for years especially on the old live axle rear ends of the old 900 series.
Old May 20, 2003 | 09:26 AM
Wesport's Avatar
Wesport
Ground Effects
Wes
Old May 20, 2003 | 01:01 PM
SB's Avatar
SB
Mud flaps sound good to me. I'll go with that. :smile:
Old May 20, 2003 | 01:12 PM
MGCMAN's Avatar
MGCMAN
Looks like F.I.A. sanctioned undercarriage boards to me. If you've worn more than 2mm away after a race, you're officially disqualified.
Old May 20, 2003 | 04:09 PM
Pamlico's Avatar
Pamlico
These have been given the highly original name of 'airflaps' by MINI. They are there to break up airflow under the car at speed. Otherwise at constant speed a booming noise would be heard inside the car. They also serve as a way to reduce drag and buffeting to a degree.
This is according to information posted on mini2.com by a tech working in the MINI factory.
Old Jun 4, 2003 | 05:42 AM
Kohu'ulaMINI's Avatar
Kohu'ulaMINI
Those are the elusive "speed limiter"
squawSkiBum
Tires, Wheels, & Brakes
27
Nov 19, 2024 10:26 AM
ebowling
90
Aug 4, 2019 09:15 AM
AdrenaliNate
Aug 24, 2015 12:37 PM
Chippawaguy
Aug 18, 2015 11:17 AM
