R50/53 Need some desperate help
Old Apr 26, 2007 | 07:13 PM
seigmann's Avatar
seigmann
Hi everyone,
I have a Mini Cooper (non-S)(And obviously I have a Cooper) and I'm wanting to switch the rear bumper for an S one. HOW THE HECK DO I TAKE IT OFF???!!!!:impatient :impatient
Old Apr 26, 2007 | 07:27 PM
200-OK's Avatar
200-OK
Well, I just took my bumper off to install the Mini Do More hidden hitch. There are some nice instructions on doing so here...
http://www.miniaturetrailer.com/instructions.pdf
Does that help?
Old Apr 26, 2007 | 10:05 PM
seigmann's Avatar
seigmann
Sort of. But how do you reach those hard to get ones?
Old Apr 27, 2007 | 01:04 AM
AZMCS's Avatar
AZMCS
What ones? It's been awhile since I pulled mine off last time, but I think it only took like 15 minutes.
Old Apr 27, 2007 | 03:59 AM
200-OK's Avatar
200-OK
Did you pull the back wheels off? Unless you do that you will need a really short screw driver. But once that is done, it really is a piece of cake...
Old Apr 27, 2007 | 04:40 AM
BlimeyCabrio's Avatar
BlimeyCabrio
+1 - I found that it's easiest to put the back of the car on jack stands (rear wheels up, front wheels on the ground). Then the rear wheels drop down enough to get a stubby phillips screwdriver in there without taking the wheels off. If you don't have such a screwdriver, you'll need to pull the wheels.
Old Apr 27, 2007 | 07:22 AM
dansmini's Avatar
dansmini
There are a couple of screws underneath the black wheel well trim, at least there were on my 2003 Cooper. I had to pull the black wheel well trim off partially to get to these.
Old Apr 27, 2007 | 10:12 AM
seigmann's Avatar
seigmann
No i'm talkin about the screws under the tailights. The manual I saw said there were two screws under the tail lights and one screw above the rear reverse light. How do I get to those?
Old Apr 27, 2007 | 10:28 AM
minimusprime's Avatar
minimusprime
4 screw total hold the back bumper on. 2 with nuts under the rear rocker panel arches and 2 are in the rear hatch bumpers.
To do it without harming anything I suggest jacking up the rear end on stands. Removing both wheels and wheel wells. then popping the trim pieces to gain access to the nylon nuts... then remove the rear hatch rubber bump stop pieces.
Old Apr 27, 2007 | 11:51 AM
AZMCS's Avatar
AZMCS
That's how I did it! Now I remember doing it.
There aren't any under the taillights, unless you are referring to the ones in the wheel wells under the liners
Old Apr 27, 2007 | 12:01 PM
seigmann's Avatar
seigmann
Ok thanks
mni928
Oct 11, 2015 07:37 PM
mini-licious!
Jun 21, 2006 03:15 PM
paulmon
Tires, Wheels, & Brakes
22
Apr 27, 2006 07:06 PM
