Drivetrain How do I get the @*&#! plug wires off the plugs??
Old Mar 17, 2007 | 11:44 AM
70spop's Avatar
70spop
Is there some trick to pulling the plug wires off so I can change the spark plugs? I've been pulling for 15 minutes, and they won't budge. There isn't some special tool needed, is there? This is ridiculous.
Old Mar 17, 2007 | 11:52 AM
Dr Obnxs's Avatar
Dr Obnxs
Nope...
no special tool. The rubber part should pop up a bit, then it's just the plug tip and the boot that it's haning on.
Pull harder?
Matt
Old Mar 17, 2007 | 01:54 PM
TLMCS05's Avatar
TLMCS05
A touch of dielectric grease inside the boot upon reinstalltion will help the next time. Make sure to do not accidently get a grip on the wire! That'l really make you unhappy! I have to fess up that I used pliers on the boot for grip the 1st time....
Tim
Old Mar 17, 2007 | 03:34 PM
norm03s's Avatar
norm03s
Give them a twist as you pull and use the dielectric grease.
Old Mar 17, 2007 | 03:41 PM
roaduscarnivorous's Avatar
roaduscarnivorous
i see you have a jcw. i have a jcw as well and was wondering what kind of plugs you're using. thanks!
Old Mar 17, 2007 | 04:31 PM
ScottinBend's Avatar
ScottinBend
Sounds like the boots have cooked themselves onto the plugs. You could use a pair of pliers and a block of wood for a fulcrum, but you will probaly need to replace the wires after geting them off.
Old Mar 17, 2007 | 04:45 PM
sndwave's Avatar
sndwave
Coordinator :: Gulf Coast & Panhandle MINIs
A easy twist CCW helps when removivg the plug wires.
Old Mar 30, 2008 | 01:15 PM
charger's Avatar
charger
Having the same issue. I can pull 150lbs dumbells at the gym -- so those plug wires sure must be baked on the plugs!
Old Mar 30, 2008 | 01:20 PM
UKSUV's Avatar
UKSUV
Damn...and I thought I was cool for reppin out 20's..
Old Mar 30, 2008 | 03:38 PM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
^I am there with you UK
Old Mar 30, 2008 | 06:56 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
I only use 10's .
Anyway, I don't see any reason that the plug boots would melt to the plugs. I've never heard of that before.
Old Mar 30, 2008 | 07:30 PM
ScottinBend
The boots can get hot enough to create a bit of a vacuum and the heat can cause the rubber to "glue" itself to the plug.
Old Mar 31, 2008 | 03:52 AM
charger's Avatar
charger
Number 1 and Number 4 plug wires tore apart. I don't think it was the rubber boot. The previous owner had installed aftermarket wires. The metal connectors on the inside gripped the plug too much. Even took some effort with needle noose pliers to get them off.
So I fixed the spark plugs and tore up the good plug wires.. :(
Old Mar 31, 2008 | 07:06 AM
ScottinBend
WOW.....!
Well at least now you can get some good ones.........
patsum
26
May 29, 2021 06:29 PM
rob76turbo
Sep 15, 2015 10:11 AM
Filmy
Sep 7, 2015 08:27 PM
rob76turbo
GP Talk (2006)
Sep 7, 2015 12:28 PM
Sep 2, 2015 09:05 AM
