Drivetrain BPV/Supercharger Intake Tube
Old Mar 30, 2008 | 03:31 PM
cwoolman's Avatar
cwoolman
During my Detroit Tuned Bypass Valve install, I broke the tab on the supercharger intake tube. The car doesn't idle right and the check engine light came on, so I need to replace the tube. I thought I saw a write up on doing this, but can seem to find it. Can someone direct me to a write up of how to disassemble the front of the car to get to the intake tube? Thanks!
Chris
Old Mar 31, 2008 | 04:43 PM
Big-Daddy-Blue's Avatar
Big-Daddy-Blue
I have done this actually!
But I drove mine for a week with the SES light on. Just make sure the intake tube is fully seated to the SC.
Remove front bumper cover. 3 bolts and 2 screws on the bottom and 1 bolt on each side in front of the wheels.
remove the metal bumper support. 5 bolts per side.
remove the plastic screw clips that hold the radiator support the the frame. there are 2 at the top (they will look like plastic rods when slide out), and 4 on each side.
This will allow you to pull the radiator back enough to remove the tube and access the bolt that holds the tube on.
I can do it all in 2 hours.
MAKE SURE YOU HAVE THE INTAKE TUBE FULLY ON THE SC WHEN RE-INSTALLING. I thought I did, and got everthing back together and it was sputtering and misfiring.
rtk90
Aug 29, 2019 09:08 AM
Sep 11, 2015 11:09 AM
COOPT UP
Sep 11, 2015 04:59 AM
ShadyCoop
Sep 8, 2015 04:50 PM
Sep 2, 2015 09:05 AM
