R50/53 tire pressure light is on..help!
Old May 20, 2006 | 12:37 PM
smokinMINI's Avatar
smokinMINI
i was just motoring along yesterday when i noticed my tire system light was turned on..pulled over and checked my tires, which are the run-flats, and everything seemed fine....checked the pressure and it was good....im stuck to why this happened!...could it be a glitch?
Old May 20, 2006 | 12:48 PM
2Miniacs's Avatar
2Miniacs
We've had this happen twice. Once when I put a bottle on the reset button and once for no apparent reason. I recommend you reset the light and see if it comes back on.
Old May 20, 2006 | 02:04 PM
marco621's Avatar
marco621
This happened to me two days ago. Checked my presusre on the tires and my one back right tire was at 16 PSI. I reset the tire pressure monitor light and filled the tire to 33PSI and it hasn't come on again.
Old May 20, 2006 | 03:09 PM
yamahogg500's Avatar
yamahogg500
check all your tires for pressure differences ,I had my light go on
and found a low pressure and a nail.only visable after tire removal.
these sensors dont sense pressure but rotational speed differences
a slick road can set the alarm on.
Old May 20, 2006 | 04:12 PM
MGCMAN's Avatar
MGCMAN
Do a search as we have several threads on this subject. Tire pressure lights can come on through U-turns, aggressive driving (gettin' rubber), diferences in tire pressure, etc. I've gotten to the point of trying a reset prior to even checking my tire pressure. It's not an infallable system, don't treat it as such.
Old May 20, 2006 | 06:02 PM
Eric_Rowland's Avatar
Eric_Rowland
First time mine went on I had just pulled onto Buttonwillow race track for the first time. That was a LONG lap. Like others, I've had it go off a couple of times - all false alarms.
Old May 21, 2006 | 03:48 AM
smokinMINI's Avatar
smokinMINI
thanks for all the responses!..yeah, i just rechecked the pressure in my tires and all were good..tires appear to be in good condition as well so im just assuming it was a false alarm...errr, or atleast i hope so!
Old May 21, 2006 | 05:01 AM
MiniMaxx's Avatar
MiniMaxx
16lbs...Yeow , that's pretty low for normal air loss. I'd keep an eye on that tire. The only time my light went on was within 2 blocks of my garage after sitting all night. I pulled over and checked and a tire was down to 19 lbs and then I found the nail . The system worked for me.
Old May 21, 2006 | 06:00 AM
kenchan's Avatar
kenchan
mine did this one time. i just reset it and never happened since over the
past 3 years.
theblackfalcon
Oct 11, 2015 09:49 AM
JamJam43087
Aug 16, 2015 02:02 PM
Terry Gallentine
Aug 11, 2015 03:31 PM
nomar116
Aug 9, 2015 09:42 AM
