Radiator fan won't shut off
Old Mar 23, 2006 | 09:58 PM
Ryephile's Avatar
Ryephile
Ok I'm stumped. The Bentley service manual, aka the P.O.S., hasn't been able to help me with this issue:
When the engine is running and only when the engine is running, no matter the coolant temp, the radiator fan is 'stuck' in high speed mode.
Bad module in the fan shroud?
ECU took a dump?
I swapped relays, that's not the problem
The only coolant fan related item I can think of is my A/C pressure line sensor is disconnected. That sensor however, only triggers the fan on if there's above 8bar [for low fan speed] and above 18bar [for high fan speed] of a/c line pressure. I'm assuming that sensor sends a high signal in correlation with pressure.
Any ideas would be appreciated,
Ryan
Old Mar 26, 2006 | 08:52 PM
Ryephile's Avatar
Ryephile
I figured it out. Everyone keep their a/c pressure sensor plugged in!
Old Mar 26, 2006 | 09:34 PM
002's Avatar
002
That gives me an idea to control the fan at will... say waiting for my turn at the drags.
Old Mar 27, 2006 | 01:46 PM
Grahamxx's Avatar
Grahamxx
Ryephile,
I had the same problem, I've enclosed pictures of the item at fault, problem is you'll need a new fan assembly:impatient
This part can't be seen until you take the fan out as it's hidden behind some plastic moulding
Graham
patsum
26
May 29, 2021 06:29 PM
battlehawk_mini
Mar 5, 2021 06:15 AM
patsum
Sep 15, 2015 09:14 PM
Racingguy04
Electrical
Sep 15, 2015 06:19 AM
shahriar35
Sep 12, 2015 08:31 PM
