Suspension Strut bar fitment issues
Old Jan 22, 2006 | 10:38 AM
early_apex
I had this strut bar on our 04:
On our 06 this bar pushes against the hood so much that you can see hood raising up slightly. Anyone else have a problem fitting a strut bar in an 06 or 05 car? Is the hood liner thicker on the newer cars or something?
Old Jan 23, 2006 | 03:49 PM
Kellzir's Avatar
Kellzir
Yeah i've noticed that the late 04's and up have a thicker hood liner.
Old Jan 23, 2006 | 04:08 PM
early_apex
sonofa...
Old Jan 23, 2006 | 10:26 PM
SpunkytheTuna's Avatar
SpunkytheTuna
So pull the hood liner and toss it into the garage.
No big deal, I've been running without the hood liner for a year with no issues arising from it.
Old Jan 23, 2006 | 10:40 PM
TonyB's Avatar
TonyB
Also, if you don't want to completely remove the liner, you should be able to trim it, or remove the portion that the bar traverses...
Spunky, I've always wondered what the liner weighs... I'm guessing about 2 lbs. If not much trouble, would you mind weighing it and sharing? Thanks much. Sorry for the OT... maybe PM'ing me would be better...
Old Jan 24, 2006 | 07:38 AM
SpunkytheTuna
And waste the opportunity to hijack a thread? Pfah!
According to my careful prosthesis, the liner including the plastic attachment clips weighs in at 1.5 lbs. Probably less weight savings than driving barefoot, but it's one less fooferaw to mess with under the hood.
I originally pulled mine out so I could work out some wiring paths for a set of led cylon type lights for the hood scoop. I was working with a guy who builds them for Honda Gold Wings to see if he could do them for a reasonable price for us. That project came acropper due to Spunky's Adventures In Health Care and I just never put the liner back in.
Old Jan 24, 2006 | 08:32 AM
TonyB's Avatar
TonyB
Spunky, thanks for the info, and the humor as well! When I removed by Xenon wiper assembly, I needed to fold-back a portion of the liner to gain access to the fluid lines. I contemplated removing the whole thing then, but my IC diverter was designed with the liner in place, and I didn't want to dork with it at the time...
The liner was thought to keep the heat off the hood, preventing the paint from blistering, but that seems to be not so. As a sound-deadener, I'm sure it muffles the SC and engine noise, but that's no biggie for me...
Thanks.
Old Jan 24, 2006 | 09:03 AM
JS's Avatar
JS
The air diverter does have two attachment points shared with the hood liner but it can be removed indepent of the scoop/diverter. This will help relieve the pressure on the brace and should allow the hood to close completely. Yes I had the problem also. Solved it this way. And lose 1 1/2 lb. to boot or rather to bonnet.
Mikli
R55 :: Clubman Talk (2008+)
Jun 26, 2019 05:58 AM
JaysinStrife
Suspension
Sep 7, 2015 12:52 PM
Rennfahrer555
Aug 13, 2015 09:07 AM
nomar116
Aug 10, 2015 11:24 PM
