Cooper (non S) Modifications specific to the MINI Cooper (R50).
Danger of drowning with a CAI?
Old Dec 2, 2005 | 03:52 PM
Drsms22's Avatar
Drsms22
Is it true that going through deep puddles with a Cold Air Intake in your car could let water into the engine and blow it up? Is that one reason why the OEM intake is shielded?
Old Dec 2, 2005 | 03:56 PM
indimini's Avatar
indimini
You'd have to go through a pretty deep puddle to get the S's intake soaked. I don't think I've enver seen a car mfr that didn't shield their intake.
Old Dec 2, 2005 | 04:07 PM
Thomas J's Avatar
Thomas J
It's not gonna happen in a Cooper S, since the intake is up by the cowl... Some CAI's made by aftermarket companies for other cars are subject to sucking up water because they put the filter down so low. I've seen a few Civic's like that, and my Datsun's CAI has sucked up water before - no permanent damage, though.
Old Dec 2, 2005 | 04:53 PM
UKSUV's Avatar
UKSUV
My BMW's CAI is down almost lower than the bumper. That can definitely suck up water. But, on a Mini, you would have to drown it.
Old Dec 2, 2005 | 05:04 PM
chrisneal's Avatar
chrisneal
This is much more of a danger with the non-S Cooper, since the intake is right behind the grille. For Coopers, an aftermarket intake seems like it would actually make hydrolock less likely. For an S, I doubt your chances would increase much.
Old Dec 2, 2005 | 05:31 PM
MarkS's Avatar
MarkS
Road & Track magazine's long term test Cooper S, with the stock intake, had to have its engine replaced because of water ingestion from driving through a deep puddle. Article here. So I guess it can happen, though it thankfully seems to be quite rare.
Mark
Old Dec 2, 2005 | 05:43 PM
not-so-rednwhitecooper
your never gonna hydrolock the motor unless the filter is COMPLETELY SUBMERGED in water. it would have to be higher than the grille. if you going thru a puddle that deep, it hink you have more important things to worry about.
Old Dec 3, 2005 | 06:03 AM
agile_moments's Avatar
agile_moments
I don't think anyone needs to worry about hydrolock unless you attach a propeller to the back of your MINI or install a CAI on your World War Two vintage DUKW. All the hype about hydrolock, I believe, comes from vendors like AEM trying to sell their joke-of-a-product: the 'bypass valve'. I never understood those things. If you have a foam element in the engine bay, next to the engine, wouldn't it negate the cold air being drawn from behind the front bumper (as is the case with placement of most CAI's)? I think it's rediculous, but that's just me.
Old Dec 3, 2005 | 06:12 AM
chrisneal's Avatar
chrisneal
You guys should do a search. This has happened to plenty of people here whose cars weren't submerged or rocket-propelled. It's very much a real issue, at least for Coopers.
Old Dec 3, 2005 | 08:19 AM
UKSUV's Avatar
UKSUV
That R & T article is flat out BS. I drive around all the time in 1 ft. puddles when it rains and have not had problems. Even if some water did enter the intake track, it would still have to pass through the filter. Then into the motor. Even if you get a small amount of water in the engine, doesn't mean it is going to engine heaven. You just drain the oil and reservice. They were probably messing around in deeper water than that and pawned it off like it was less. That's my theory. Because that's what people do.
Old Dec 3, 2005 | 01:10 PM
yes, cars with stock intakes.
there are long tubes that go down to near the bottom of the chassis to pick up air on our cars from the factory. they pick up air from the fenderwell too, it looks like.
When you go aftermarket, the entire way the car pics up air changes, and it sucks from the grill and the engine bay only. theres little or no chance you would ever suck up any water with an aftermarket unless the car was halfway submerged under water.
Old Dec 3, 2005 | 01:14 PM
Battle Cattle's Avatar
Battle Cattle
what he said... ^^
-Josh
Old Dec 3, 2005 | 01:23 PM
agile_moments
what they both said ^^
Old Dec 8, 2005 | 04:12 PM
kenatminimania's Avatar
kenatminimania
Yes, there is a resonance chamber in the drivers side fender that is attached to the intake tube. Some MC's have ingested water from this area, causing hydrolock.
ken
Old Dec 9, 2005 | 09:31 AM
deerharb's Avatar
deerharb
Damaged motor from ingesting water
A few years back, I bought an 02 MC from auction that had a motor that "would not run". I found that the motor had four broken connecting rods and as they broke, they "kicked windows' in the side of the block. Each of the four combustion chambers was full of water. The intake manifold was full of water. The air filter box had the filter in place, but the box was dry because it has a drain hole. There was no water or evidence of flooding inside the car, so I concluded that the car had been driven through a puddle and water welled up in front as it was moving through a puddle causing water to pour into the snorkel above the radiator. It would only take a 1/2 cup or less per cylinder to hydraulic. I was amazed that all the rods were broken and none were bent. Then I found that they were sintered and not steel forgings.
After replacing the motor (got one out of one of the Minis that appeared in the movie "The Italian Job", my wife drove it for another 15k miles with no problems.
Old Dec 9, 2005 | 10:00 AM
J0kER's Avatar
J0kER
mystery to me too
but that foam element/bypass valve does werk to remove the possibility of water becomin' a problem b4 it gets thru the intake.
a close friend of mine runs an AEM & is sold on the idea specially since its saved his *** a few times i've seen the mess the water makes under his hood a couple times so to me it werks....
as far as it werkin' well as a CAI, im w/u. i dont see it as its forte'......
Pker
Apr 11, 2017 12:14 AM
slash695
Apr 26, 2016 06:27 AM
Shomare
39
Oct 19, 2015 03:33 PM
simo711
Oct 8, 2015 07:07 PM
pglgp1292
GP Talk (2006)
Oct 2, 2015 10:34 AM
