Suspension '05/06 Rear Camber Adjustment
Old Nov 27, 2005 | 04:02 PM
dave's Avatar
dave
pug poo picker-upper
I searched and I couldn't find it.
I keep hearing that the '05 and '06 MINIs have a rear camber adjustment. Here's the $64,000 question: Where is it? (photos if you got them. )
Thanks in Advance,
Dave
Old Nov 27, 2005 | 04:52 PM
Byron's Avatar
Byron
I believe you are refering to the star wheel on the bottom of the lower control arms.
Old Nov 27, 2005 | 05:57 PM
CoryB
I don't have a picture (too dang cold to lay on the ground under the car right now) but the early '05s (2004 build) didn't have the camber bolts in them. Only January 2005 and forward have them.
Old Nov 27, 2005 | 07:18 PM
Passat774's Avatar
Passat774
See my gallery I have a picture.. Taken when it was warmer
Old Nov 27, 2005 | 07:57 PM
SJJ28's Avatar
SJJ28
its a cam bolt like BMWs have. Still not nearly enough adjustment for a lowered car though, I had -3deg each side with iot all the way out!!
Old Nov 28, 2005 | 01:21 AM
Steeroidz's Avatar
Steeroidz
Would adjusting just the rear camber make an improvement to the cars street handling?
Old Nov 28, 2005 | 04:46 AM
petecrosby's Avatar
petecrosby
Not really, since there is already about -1.5 degrees in the rear from the factory. What you need for better handling on the street is a rear sway bar and more front camber.
Old Nov 28, 2005 | 05:44 AM
dave's Avatar
dave
Great. Thanks for the picture.
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
ebowling
90
Aug 4, 2019 09:15 AM
Minibeagle
Aug 13, 2015 10:00 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
OutMotoring
Aug 6, 2015 09:32 AM
