Loud squeak at ignition and clutch engagement.
Old Aug 22, 2005 | 06:02 AM
GMINIO's Avatar
GMINIO
Not constant. But yeesh. How high pitched can it be? anyone heard such a thing?
It happends when starting the car (sometimes) and when slipping the clutch into a load. ~1 second long.
If this sounds like a problem I might have trouble getting a MINI tech to diagnose, you'd be right.
New clutch installed earlier this summer for other reasons. Sound has been happening for a month.
Old Aug 22, 2005 | 06:12 AM
bodinski's Avatar
bodinski
Sometimes I get a loud squeak/chatter at 1st gear engagement. Not all the time, & when it does it's usually when the motor bogs a little - like starting out on a hill. I first noticed it after installing a custom exhaust about 18k miles ago. Thought it was something to do with that, but I've changed it twice since then & it still happens from time to time. Some people have complained of flywheel noise. I wonder if that's what it is..
Old Aug 22, 2005 | 09:52 AM
GMINIO's Avatar
GMINIO
dead-on, bodinski! I've tolerated that chatter from the day i drove it out. Just a jcw thing i said to myself. But that squeak that evolved ain't earthly. gremlins, baby. does the motor bog with dsc off? i atributed it to the software. be interesting if you had none, and if when i turn mine off - it continues to do so.
Old Aug 30, 2005 | 06:03 AM
bodinski's Avatar
bodinski
I don't have JCW anything, nor do I have DSC. It doesn't bog much, just when I'm a little stingy with the throttle at engagement, and especially on an uphill grade. Doesn't seem to be getting any worse..
Old Sep 16, 2005 | 03:40 PM
GMINIO's Avatar
GMINIO
ok when i've tried to pull away in the wrong gear (apparently third feels to my hand a bit like first), I hear a squeak of high pitch accompanying the knock of the engine working against the tranny.
That same high pitch squeak is the initial sound i hear upon ignition. Most of the time.
Old Sep 17, 2005 | 03:40 PM
lvbltec's Avatar
lvbltec
maybe a driver issue if u get same squeek when starting in 3rd as in 1st
Old Sep 17, 2005 | 04:08 PM
chows4us's Avatar
chows4us
The "knock" your hearing will happen in any manual car. Your RPMs are too low for that gear and its NOT good for your car. Dont do that
Old Sep 17, 2005 | 08:53 PM
GMINIO's Avatar
GMINIO
thanks for the pointer. i know that one should avoid undue engine strain and how that strain is produced. not wondering about the knock. it's the squeak has me annoyed. on start up especially.
and tony... you mean nut-behind-the-wheel driver or the inner driver or something else?
Old Sep 18, 2005 | 06:30 AM
lvbltec's Avatar
lvbltec
some people come in hearing a rattle and i have to tell most of them to stop shaking their heads
Old Sep 18, 2005 | 06:43 AM
GMINIO's Avatar
GMINIO
lol
any inclination to specify which driver might be causing this, in case you weren't joking?
happy at the new job?
Old Sep 19, 2005 | 10:06 AM
lvbltec's Avatar
lvbltec
anyone with the last name starting with a-z especially E
yes actually
lol
Old Sep 19, 2005 | 09:40 PM
GMINIO's Avatar
GMINIO
yes actually
I'm realy glad to hear it, tony, especially after seeing you work it late on saturday with a line of MINIs out back. Couldn't make me face that. now, uhhhhh, i guess we've got your input as far as possible diagnosis of a squeaking starter is concerned.
cheers.
Old Sep 24, 2005 | 07:42 AM
lvbltec's Avatar
lvbltec
probly a flywheel had some trouble with the dual mass flywheels making all kinds of noise even a click like your cv makes mostly sound like a bird clirping
cheers.
lweaver
Sep 17, 2024 08:22 AM
Colt45Magnus
Aug 27, 2024 05:03 AM
patsum
26
May 29, 2021 06:29 PM
Sep 10, 2019 09:22 PM
Sc00terbum
Sep 11, 2015 07:17 AM
