Engine Code Definition NEEDED
Old Jun 13, 2005 | 05:15 PM
JCampos's Avatar
JCampos
The code reader I have is generic and doesnt tell me what the make specific codes are. Can someone with a book of the engine codes tell me what P01689 is please?
Old Jun 13, 2005 | 05:25 PM
JustGo4It_'s Avatar
JustGo4It_
the code should be 5 digit
P=powertrain
0=SAE
1=air/fule induction
ae you sure about that # ?
you have a 2004 right?
Old Jun 13, 2005 | 05:27 PM
JCampos's Avatar
JCampos
fairly sure. why? cant find it? Its easy to throw it, so ill go do it and come back
Old Jun 13, 2005 | 05:30 PM
JustGo4It_'s Avatar
JustGo4It_
the book goes from p0141 o2 sensor then goes to p0171 system too lean bank one.
Old Jun 13, 2005 | 05:34 PM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
P1689: Electronic Throttle Control Monitor Level 2/3 Torque Calculation Error.
Old Jun 13, 2005 | 05:45 PM
tsprayfhs's Avatar
tsprayfhs
p1689 is "Electronic Throttle Control Monitor Level 2/3 Torque Calculation Error" Good luck.
Motor on
Old Jun 13, 2005 | 05:48 PM
JCampos's Avatar
JCampos
wow... sounds fun. how about
P0107
P0108
?? You think this would be a wiring harness, throttle body, or throttle position sensor problem??
YYC's Avatar
YYC
Greatbear with the info again!!! Unbelievable!! How do you do that!?
Old Jun 13, 2005 | 05:58 PM
JustGo4It_'s Avatar
JustGo4It_
P0107 manifold absolute pressure / barometric pressure circuit circuit low input
P0108 manifold absolute pressure / barometric pressure circuit circuit high input
Check your T-MAP sensor near the electronic throttle valve housing.
Old Jun 13, 2005 | 06:34 PM
Greatbear's Avatar
Greatbear
Ancient Ursine Secret!
Old Jun 14, 2005 | 05:33 AM
haskindmh's Avatar
haskindmh
It won't do you much good to just get the code number translated. The code will tell you which diagnostic tree to follow. You will then need a manual to folow the proper diagnostic procedure. This will tell you why that part is providing a signal to the computer that is outside of the expected parameters. This MAY be due to the part being defective, but it may also be caused by many, many, other things. Codes mean very little by themselves. You must follow the diagnostic procedure or you will just end up "throwing parts at a problem" and hoping to get lucky. That is fine if you are a dealership mechanic that gets paid for replacing parts and the factory is paying for the parts, but dosen't work very well for actually correcting a problem.
Old Jun 14, 2005 | 09:16 AM
JCampos's Avatar
JCampos
I know... I just needed to know whether I had a vacuum leak or a mechanical error. Now I just gotta track it down.
Old Jun 14, 2005 | 09:22 AM
Greatbear's Avatar
Greatbear
If you have altered your throttle body or added something like the AGS, you could throw this code. This is one in a series of non-generic ("P1" instead of "P0") codes relating to the drive-by-wire throttle system. Early versions of the AGS came with an extension cable to connect the relocated throttle body to the engine harness. Some of these cables have been defective or intermittent.
Old Jun 25, 2005 | 02:11 PM
JCampos's Avatar
JCampos
Got another one for anybody with that handy little book.
P1109
Old Jun 25, 2005 | 02:26 PM
cristo's Avatar
cristo
Alliance Member
P1109 Manifold Air Pressure too High in Deceleration
Old Jun 25, 2005 | 07:08 PM
002's Avatar
002
Jason,
Mini replaced the bypass valve, in the stock car that I have, after that code popped up. I don't know if that was actually the problem, but that's what they did.
Edit: p1689 was programmnin. p1688 was bypass valve.
Old Mar 30, 2009 | 02:26 PM
golden_child's Avatar
golden_child
Coordinator :: Capital Area MINI Modders
P1109 just popped up for me over the weekend. Any Idea on a fix?
Doesn't look like a popular code around here.
R60abq
R60/R61 Stock Problems/Issues
Jun 6, 2017 05:15 PM
Zettinger
Aug 25, 2015 04:04 PM
chicohuahua
22
Aug 20, 2015 11:17 AM
xpunisherx
Aug 10, 2015 10:50 PM
