R56 Driver's seat won't slide
Old Apr 19, 2026 | 11:15 AM
SuperDave010's Avatar
SuperDave010
My driver's side seat is stuck - it won't slide forward or back. I can tell that the issue is with the inside track - the outside track is releasing, but the inside one is not. I would remove the seat, but I'm the position it's stuck in I can't get to the bolts. I tried spraying penetrating oil on the mechanism, and that didn't help. Any suggestions?
Old Apr 19, 2026 | 01:25 PM
Raymo2u's Avatar
Raymo2u
I would have someone sit in the seat and hold the bar up and you or someone else in the backseat pull as hard as they can backwar, this will provide much more leverage against the chair. If the seat budges, then the bolts should be able to be removed and then you can observe what the actual issue is.
CaMiniMe
Sep 2, 2024 09:50 AM
bobwoodly
May 4, 2008 08:57 PM
byhsu
Dec 16, 2007 10:53 PM
Turcicus
Jul 23, 2007 04:06 PM
Deli
Aug 29, 2004 05:29 AM
