R56 5dab
Old Mar 9, 2026 | 01:28 PM
302Vernon's Avatar
302Vernon
5dab
Hello Mini Heads!
Not much on the code above but I was told by a local shop that my abs control module is bad. I have the Brake, abs and triangle woth arrow lights on the dash. Apparently these modules are over 2k new. I was told to get one on ebay or 2nd hand. I found one at AllMag mini parts for $225. Ive seen on YouTube that after swapping it out it has to be programmed by dealer or by very specific scanner that has bidirectional features. Can anyone confirm that code is related to the abs module? Also, I recently changed all 4 abs speed wheel sensors to no avail. Thanks!
Old Mar 9, 2026 | 03:42 PM
Maybe, maybe not's Avatar
Maybe, maybe not
Community Builder
Community Influencer
2010 mini cooper S?
Have your tried clearing the code with a scan tool?
Have you ruled out low voltage issues. Does your battery hold 12.6V when engine is OFF and ~14V when engine is running?
Have you checked the ABS/DSC control module connector for corrosion or pin damage.
Old Mar 9, 2026 | 03:49 PM
302Vernon's Avatar
302Vernon
Originally Posted by Maybe, maybe not
2010 mini cooper S?
2010 Cooper S. 108k miles
battery is 12.08 off and around 14.40 on.
Foxwell elite NT510 scanner.
lights come back on immediately after car put in gear after clearing them.
Havent checked the abs module as far as corrosion. Dont want to take the car out of service just yet.
Old Mar 9, 2026 | 04:04 PM
Maybe, maybe not
Community Builder
12.08 is a very low battery voltage. If your fully charged battery can't hold a higher voltage overnight, then the battery may be bad or the electrical system has a parasitic draw.
Old Mar 9, 2026 | 04:06 PM
302Vernon's Avatar
302Vernon
Battery is 4 years old now. Do you think that would give me those engine lights for traction control, abs and e brake? While the scanner gives me that 5DAB code?
Old Mar 9, 2026 | 04:10 PM
Maybe, maybe not
Community Builder
Low system voltage in Mini Coopers can cause many different problems. Given the high price of a replacement ABS/DSC control module, it would be wise to rule out the other possibilities first.
Old Mar 9, 2026 | 05:10 PM
302Vernon's Avatar
302Vernon
Advanced auto tested my battery and said it was working fine and was 12.25 amps But the cranking was a bit low. Bought a higher AGM battery and just installed it. No change in the car. Still lights on dash.
Old Mar 9, 2026 | 05:13 PM
Maybe, maybe not
Community Builder
What is the new battery voltage with engine off? Once battery is fully charged to 12.6V, try again to clear the code to see if it returns.
Old Mar 10, 2026 | 03:21 AM
scook179351's Avatar
scook179351
Abs
Hello,
i went through this on our first MCS and the contacts were corroded on the ABS module. Ended up replacing the module and maybe the cable if I remember correctly.
Old Mar 10, 2026 | 04:06 AM
302Vernon's Avatar
302Vernon
Originally Posted by scook179351
Hello,
Did you replace just the module portion or the entire unit, including the hydraulic motor? The module is about 1300 and the unit w hydraulic unit is 2700. Did a dealer do it, because I've read it had to be coded with the Vin. Thanks for the reply
Old Mar 10, 2026 | 05:51 AM
scook179351
I believe it was just the module, the hydraulic unit was fine. Yes, it was done at a dealer but not sure if it had to be coded to the car though
Old Mar 10, 2026 | 05:56 AM
Maybe, maybe not
Community Builder
Coding is generally required when a control module is replaced. The Foxwell elite NT510 should have coding capability.
Old Mar 10, 2026 | 06:12 AM
302Vernon's Avatar
302Vernon
I bought the Foxwell elite but from what I have seen on various posters is that in order to program the module, you need a scanner/software they has bi-directional control, meaning the ability to to send codes from the device to the car. The elite foxwell does not have that ability from what I gather. One would need software called ISTP-A to program the module.
Old Mar 10, 2026 | 06:17 AM
302Vernon's Avatar
302Vernon
Old Mar 10, 2026 | 07:27 AM
Maybe, maybe not
Community Builder
The 5DAB fault code seems to indicate a bad pump motor not a bad control module. If you have your pump motor professionally repaired, no programming or coding would be required. You would only need to use your Foxwell to calibrate the steering angle sensor and to bleed the hydraulic system.
But first use a multimeter to test whether fuse FL6 or FL8 is blown.
Old Mar 10, 2026 | 01:19 PM
302Vernon's Avatar
302Vernon
those 2 fuses inside look to be in tact. But sure how to test them with a meter due to them being a box.
is
is the round part the motor, correct? That can be taken apart and power run to it to see if it rotates?
Old Mar 10, 2026 | 01:47 PM
Maybe, maybe not
Community Builder
Yes, that's the pump motor. Warning: Avoid trying to access the motor by removing the cover.
There's a better test. Check whether the ABS/DSC connector pin for the Red/Violet wire reads 12V with key ON. This is voltage for the pump.
Voltage for the control module is a Red/Black wire.
The grounds are generally brown wires.
Old Mar 10, 2026 | 02:46 PM
302Vernon's Avatar
302Vernon
that pic is the used one that I sourced from AllMag parts. Mine is still in the vehicle.
Old Mar 10, 2026 | 02:49 PM
Maybe, maybe not
Community Builder
Got it. If you can disconnect the ABS/DSC module connector, then you may able to test voltage and ground at the 4 connector pins.
analyte
Jun 11, 2025 01:30 PM
Eric.
Sep 13, 2017 07:45 AM
stiles165
Apr 17, 2017 08:20 PM
guka747
Sep 28, 2016 01:54 PM
Topper Sloan
Jul 10, 2015 08:31 AM
