R57 Cooper S - Cooling System Temp Sensor
Old Nov 22, 2025 | 01:50 PM
kingisdead's Avatar
kingisdead
I have a coolant leak. Added UV dye to help locate.
Leak is coming from a temp sensor (136 326 10 GE) located on a 90deg elbow. No problem there - it's easy to locate and I can replace the O-ring.
Im confused as I know this is not the main temp sensor (which is located in the thermostat housing) and there is no wiring connector to the sensor in the elbow (and no spare wires in the vicinity that should be connected to it)
Did mini fit a redundant sensor as it was an available / cheap part?
Or has someone before me bodged a repair with a elbow connector and a 'slave' sensor.
I know from the OBD my car is registering coolant temp. It appears this sensor isn't doing anything?
Can anyone confirm?
Old Dec 1, 2025 | 12:17 PM
Hello,
Its the same sensor they used here on the certain Countryman models for a short time.
When you change out the thermostat the first time after the original, you factory bypass that sensor.
https://www.northamericanmotoring.co...ntryman-s.html
Briscoec
Apr 27, 2021 11:24 AM
geoff0076
Jun 4, 2020 07:36 PM
PinkMiso
Nov 27, 2018 02:51 PM
BChili
Oct 11, 2011 08:53 PM
minikania
22
Apr 2, 2011 09:00 AM
