F54 :: Clubman Talk (2015+) MINI Cooper Clubman and Clubman S Discussion
F54 2020 F54 JCW Clubman Suspension
Old Nov 14, 2025 | 06:22 AM
YLWR56's Avatar
YLWR56
Hello all. I recently purchased a new to me 2020 F54 JCW Clubman launch Edition. I'm planning to purchase the Eibach lowering springs and larger rear sway bar as I'd like to get rid of some of the factory fender gap and get it to sit a little lower and handle a little better. My car has the adaptive dampers (DDC).
My question is for those that have done this same mod. When you lowered the car on the lowering springs, did the car have enough ability to adjust the camber already built in, or did you purchase lower rear control arms to get the camber adjusted properly in the rear? I'm trying to determine if the lower rear control arms are necessary, or if I can get away with the ability to adjust as is. I've no problem purchasing the control arms and installing, just wanted to see if it was ultimately necessary. My goal is to get the car to a factory camber setting at the new lowered ride height. The Eibach springs state that they give 1.2" front and 1" rear lowering to the ride height.
Also, at the new lowered ride height, was there any need to cut the bump stops?
I'm new to the 3rd Gen cars as my other MINI is a heavily modified R56 Cooper S with coil-overs, sway bar and lower rear control arms among the many suspension mods. Getting the ride dialed in is one of my favorite things to do with these cars. Really wanting to dial in the potential on this F54 as well! Any insight is greatly appreciated!
Old Nov 14, 2025 | 10:34 AM
YLWR56's Avatar
YLWR56
My 2 MINIs.
Old Nov 14, 2025 | 12:14 PM
Hello,
Sweet F54! Hopefully this helps.
https://www.northamericanmotoring.co...g-springs.html
https://www.northamericanmotoring.co...mendation.html We dont carry AC but gives you ideas what to use and drop.
https://www.northamericanmotoring.co...-wheels-2.html
Old Nov 15, 2025 | 05:13 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Nice! I like the Launch Edition F54s.
I would be tempted to cut bump stops to preserve some damper travel. The instructions with the springs might actually call it out.
Old Nov 16, 2025 | 11:53 AM
midnightF54's Avatar
midnightF54
Didn't JCW come with electronic suspension?
My F54 has adjustable suspension and after consulting with Mini gurus, I was advised against doing ghetto drops.
The adjustable suspension can be changed to a non adjustable - then one can do whatever one wants.
Old Nov 17, 2025 | 01:19 PM
Alpha Motoring's Avatar
Alpha Motoring
DDC was an available option even on the JCW models, and there are lowering springs specifically designed for cars equipped with DDC. There’s really no difference in the installation compared to any other vehicle—just choose whatever fits your budget and goals.Alternatively, you can switch to coilovers and run a DDC cancellation kit, such as the one from KW. The car will still function without the cancellation kit, but you’ll have a persistent error message on the dash.
Old Nov 17, 2025 | 07:50 PM
midnightF54
​​​​​​​Yeah...no thanks.
dannieh42
May 15, 2024 09:14 PM
THE ITCH
Sep 20, 2022 11:03 AM
sootyvrs
Aug 26, 2016 05:35 AM
mrbean
Suspension
May 30, 2012 12:44 PM
IrishCooper
Suspension
26
Mar 26, 2007 04:57 PM
