Still dealing with this misfire
Old Oct 29, 2025 | 06:44 PM
Rh1988's Avatar
Rh1988
Hi guys i have a 2010 mini base and still dealing with a misfire had a burnt valve in cyl. 1 so far lapped new valves in did timing new plugs coils and injectors new intake manifold new catalytic converter and both o2 sensors new cam sensors compression across all 4 cylinders is 205psi good fuel pressure not sure what direction to go and have about 15 days to figure out to get emissions test and plates
Old Oct 31, 2025 | 10:42 AM
Maybe, maybe not's Avatar
Maybe, maybe not
Community Builder
Community Influencer
Pull the spark plugs and inspect. Does the inspection suggest engine is running rich? Post pictures.
You mention the plugs and coils are new. Post brands, types, and plug gaps.
274E
2772
2773
2782
2783
Old Oct 31, 2025 | 02:05 PM
Rh1988's Avatar
Rh1988
274E
2772
2773
2782
2783
thank you for the response i will pull plugs again tomorrow and take some pics last time i had the plugs out they all looked like they were running on the lean side as far as the brand of plugs the guy i bought the car from bought the coils and plugs before i scoped it for him and found out the valve was burnt out the plugs just say iridium on them
Old Oct 31, 2025 | 02:13 PM
Maybe, maybe not
Community Builder
If you can't reliably verify the age of the spark plugs and coils, it would be wise to simply replace them and then go from there.
Old Oct 31, 2025 | 02:18 PM
Rh1988's Avatar
Rh1988
i work with the guy i purchased it from and he purchased the plugs and coils in April and the car never was driven other than onto a trailer to bring to my house so i do know for a fact they are new but knowing the guy it was probably the cheapest stuff he could get for the car off rock auto
Old Oct 31, 2025 | 02:20 PM
Maybe, maybe not
Community Builder
Old Oct 31, 2025 | 02:28 PM
Rh1988's Avatar
Rh1988
so that being said you still recommend getting new??
Old Oct 31, 2025 | 02:33 PM
Rh1988's Avatar
Rh1988
Heres a pic of the head when i had it off
After hot tank
Old Oct 31, 2025 | 02:39 PM
Maybe, maybe not
Community Builder
If I thought that the plugs and coils were cheap aftermarket parts, I would replace them in a NY minute.
And the refurbished head looks great. I'm looking forward to you solving the misfire issue, and the smooth running engine puts a smile on your face.
Old Oct 31, 2025 | 06:07 PM
Rh1988's Avatar
Rh1988
what brand plugs would you recommend im kinda tight on funds at the moment so i will get plugs first and then coils if need be. Being a body man I did a custom job on the outside to gift to my 16 year old daughter but definitely wish I would’ve got running right before that🤣 and yes the smooth running engine will definitely put a smile on my face and my daughters aswell cuz i will stop telling her she has to stay home so i can work on her car🤣
Old Oct 31, 2025 | 06:37 PM
Maybe, maybe not
Community Builder
Wow, looks great! Your daughter will love it.
I'm an NGK spark plug fan, but they are pricey. Others may be able to guide you to good but less pricey alternatives.
Old Nov 1, 2025 | 05:09 PM
Rh1988's Avatar
Rh1988
me aswell i have always put ngk in everything i own so ngk it is will have them in a couple days and then i will tear back into it also got a fuel filter coming no clue if that has ever been changed. And yes she does love the car she did ask if i would paint her wheel black so guessing that will b in the near future aswell 🤣
Old Nov 7, 2025 | 05:38 PM
Rh1988's Avatar
Rh1988
Cyl1
Cyl1
Cyl2
Cyl2
Cly3
Cly3
Cyl4
Cyl4
replaced them with lazer iridium ngk and also put the old coil packs on instead of the cheap aftermarket ones so far the light is off and haven’t counted any misfires but need to take it for a drive
Old Nov 7, 2025 | 06:47 PM
Maybe, maybe not
Community Builder
Nice start! Good luck.
Old Nov 7, 2025 | 07:09 PM
Rh1988's Avatar
Rh1988
thanks but back to the drawing board engine light back and back to missing after a good drive
Old Nov 7, 2025 | 07:50 PM
Maybe, maybe not
Community Builder
Misfire in cylinder 1 as before?
Old Nov 8, 2025 | 02:13 AM
Rh1988's Avatar
Rh1988
yes
Old Nov 8, 2025 | 04:55 AM
Maybe, maybe not
Community Builder
You may want to swap fuel injector 1 with one of the other fuel injectors to see if the misfire fault code follows injector 1.
Old Nov 8, 2025 | 06:27 AM
Rh1988's Avatar
Rh1988
ok i will either try that later tonight or tomorrow morning depending on when the kid decides to be home with her car lol
Old Nov 8, 2025 | 07:31 AM
Maybe, maybe not
Community Builder
The black soot on all 4 spark plugs suggests a rich condition or that all four cylinders are experiencing misfires. Curious.
Cyl1
Cyl1
Old Nov 8, 2025 | 07:56 AM
Rh1988's Avatar
Rh1988
it does have a code for combustion misfires in several cylinders
Old Nov 8, 2025 | 08:02 AM
Maybe, maybe not
Community Builder
Did spark plug 1 look more sooty or different in any way from the other 3 plugs?
Old Nov 8, 2025 | 08:25 AM
Rh1988's Avatar
Rh1988
they all look pretty similar to me but
left to right 1-4
maybe 4 looks a lil more sooty
Rh1988
Jun 13, 2025 05:35 AM
SebR56
May 10, 2023 08:04 AM
1silvermini
Jun 15, 2022 09:06 AM
William Mejia
Oct 20, 2020 03:32 AM
FamousFlea
Dec 12, 2018 02:10 PM
