I have a 2010 Cooper S with a cylinder 4 slight misfire on idle only. Misfire clears up with the slightest increase in RPM . I have swapped injectors, and coil packs...no change.
did you do a compression test? how many miles? timing chain ever replaced? carbon cleanup on the intake valves? did you also swap spark plugs, are they gapped properly?
I did a compression test and they were all between 10% of each other ,the timing chain and guides,tensioner was recently replaced.i swapped the plugs and had the same results.checked the timing 3 times
It’s throwing a P0304 code for misfire as well as the check engine light. I soaked the valves in sea foam overnight but did not get them walnut blasted
