R56 oil turbo feed lines
replaced the turbo oil lines and the oil filter housing gaskets as part of the major service.
About to button the car up today - should I dry fire the car? Pull the fuel pump fuse and crank it a few times to build oil pressure? To a) check the pressurized part of the system for leaks and b) don't fire the engine totally dry when I do eventually start it up
I have a ECS scanner so I can clear the stored codes I'm sure will pop up as I have a bunch of sensors disconnected
DVSoul
R55 :: Clubman Talk (2008+)
Sep 23, 2024 03:50 PM
