R56 Fun Fuel Issues! - HELP Needed!
Old Jul 9, 2024 | 07:40 AM
MMVH5150's Avatar
MMVH5150
Hi all,
2013 R56 S that now is a no start..
Was driving last week and went to pass someone. As i got into boost, the car cutout, Low power mode came on and a CEL. pulled the code P142E code "Cylinder Injection Cutoff, Pressure Too low In High-Pressure System Bank 1".
Pulled into where I needed to go down the road. Cleared the code. Went to drive it again, it started but I tried getting into boost and start to buck. Drove slowly on my way home and as I was coming off of a light the car dies. Will not start back up.
Codes pulled: P0087 - Fuel Rail System Pressure too Low Bank 1and P10FB - Fuel Rail Pressure Sensor Pressure Low Before Engine Start (Bank 1)
I replaced the HPFP 8,000 Miles ago, as of 2 weeks ago replaced both the LPFP and Fuel Filter. I just re-replaced both of fuel pumps again as well thinking maybe one was bad, no go.
I just pulled of the HPFP Drive assembly and it looks slightly worn one side is flatter than the other but nothing that i believe wouldn't cause it to at least build some pressure.
I also cut the JBE open a few months ago to replace the fuel pump relay.
Dealer had the car for a few days, they said the car will build low pressure fine its high pressure that is the issue.
Any guidance here would be greatly appreciated!
Old Jul 9, 2024 | 08:29 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
If you haven't checked the fuel pressure sensor, might give that a shot...
https://www.ecstuning.com/Mini-2013-...h/13537537319/
Old Jul 9, 2024 | 08:48 AM
MMVH5150's Avatar
MMVH5150
That was recently replaced as well :/ probably 2k miles ago
Old Jul 10, 2024 | 07:12 AM
Maybe, maybe not's Avatar
Maybe, maybe not
Community Builder
P0087:
Old Jul 10, 2024 | 04:33 PM
MMVH5150's Avatar
MMVH5150
Thanks @Maybe, maybe not . I am awaiting a new fuel rail pressure sensor tomorrow. Out of curiosity, lets says that was bad. Would that cause a no start condition or would it still allow the vehicle to start in limp mode?
Old Jul 10, 2024 | 06:29 PM
MMVH5150's Avatar
MMVH5150
Alright SO. Tonight i replaced the HPFP Drive along with a donor JBE. Still nothing. It appears the new LPFP i put in has a burned "red" wire on the motor. I put the old one back on the motor kicked on but i still cant build pressure. I am wondering if maybe the fuel filter seals blew out. Going to check things tomorrow and get back.
Old Jul 11, 2024 | 01:42 PM
MMVH5150's Avatar
MMVH5150
Another update. Went to put another new fuel rail sensor on the older connector slid right off. Apparently it was seated correctly and was a bear to get reseated on the new one but i got it on. Awaiting a new fuel filter assembly that comes in tomorrow and a new LPFP. Fingers crossed.
Old Jul 11, 2024 | 02:13 PM
Maybe, maybe not
Community Builder
Generally, a bad fuel pressure sensor would not cause a no-start condition and more commonly would cause a hard start problem or limp mode.
Old Jul 13, 2024 | 03:03 PM
MMVH5150's Avatar
MMVH5150
Fuel filter housing and new LPFP came today. Got it re-assembled and it's RUNNING! It appears one of my MAF sensor wires is broken so once I get that fixed up I should be good to go. Thanks for all the help
thebombardier
Dec 24, 2023 04:09 PM
jcslocum
Sep 23, 2023 11:57 AM
OregonMike
R55 :: Clubman Talk (2008+)
Nov 28, 2022 11:23 AM
Davers
May 27, 2022 12:53 PM
Gottoon
Jun 13, 2011 07:18 AM
