F55/F56 Caliper piston rebuild help
Old May 1, 2024 | 12:04 PM
BlackCatBandit's Avatar
BlackCatBandit
How do I get the boot/seal off the caliper? It seems like its glued in there. Do I need to remove the piston housing somehow?
If anyone has any guides on how to rebuild the caliper that would be great, the boot is ripped so I bought a rebuild kit from rockauto.
Mando 219/ BMW 30 259-10
Thanks!
Old May 1, 2024 | 12:59 PM
thefarside's Avatar
thefarside
I can't tell if the piston is still in situ.
You must remove the piston to remove the boot.
I use an air gun into the supply port and a thick rag or a chunk of 2x4 to prevent the piston from banging into the far side of the caliper.
None of the Mini calipers I've rebuilt use a retaining ring for the boot. Once the piston is out, boot should pull off, it may be stuck due to corrosion.
Make sure the grooves for the boot and piston seal are clean of corrosion and use a generous amount Sil-Glyde or equivalent in both grooves.
Check YouTube for brake rebuild videos
Shotgun_banjo
Mar 26, 2022 02:05 PM
vivi2magic
Dec 22, 2020 11:26 AM
camucho
R60/R61 Stock Problems/Issues
Jul 27, 2015 11:56 AM
donjulio
Tires, Wheels, & Brakes
Jan 3, 2012 05:19 AM
jlasersmith
Dec 8, 2011 09:49 PM
