R56 2010 mcs , metal in oil...
Old Mar 29, 2024 | 09:44 PM
MiniManAdam's Avatar
MiniManAdam
Community Builder
So I changed a buddies oil today AND FOUND THIS in his filter and some in the oil.He had a catchcan and I thiiiink he put in the brillo pad cleaner style filter packing for it and I thiiiiiiiink that THATS what this stuff is As it broke down from the oil and cleaners that went through the catchcan. The car actually runs fine ( other than abit excessive oil consumption) but if it were rod bearing wouldn't it be copperish colored and magnetic? This stuff looks like stainless steel or aluminum.
I also did his oil last change like 6k miles ago and there was nothing of concern last time..
Old Mar 30, 2024 | 04:49 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
If there is any consolation, the filter did its job
Old Mar 30, 2024 | 07:14 AM
Maybe, maybe not's Avatar
Maybe, maybe not
Community Builder
That's a lot of debris and metal.
Old Mar 30, 2024 | 08:15 AM
MiniManAdam
Community Builder
lol I said that too..
I popped off the valvecover and didnt find anything uptop or any flaking of the cams like the r53..
his car does use alot of oil and he does alot of driving and I mean ALOT , like 3k a month !
but I fear he might maybe have gone too low on oil and the engine might have chewed up some of the bearings.
but then again , with that amount of metal , would it not be starting to tick , tap or knock atleast Slightly ???
here's what the cheapo cans come with as a filter element, id NEVER run it in mine and told him not to also but he often doesnt take my advice..
Old Mar 31, 2024 | 04:51 PM
mkov608's Avatar
mkov608
I'd take an oil sample and send it to Blackstone; metal analysis can tell you if it's bearing material. I'd suspect the oil pump because I've seen those come apart.
Old Apr 2, 2024 | 05:40 PM
MiniManAdam
Community Builder
I would too but he didn't want to...
here's more pics once the filter drained more..
Theres about 5x more metal too than pics show , it just wouldnt show up well in pics but the filer is loaded , like almost solid chunks in the grooves of the filter.
Old Apr 3, 2024 | 08:07 AM
Yep thats a bunch. Check that oil pump/strainer.
Old Apr 6, 2024 | 06:53 AM
MiniManAdam
Community Builder
I advised him I should but he kinda doesnt take advice when given , my freinds kinda one of those "I know better " types.. lol
I don't think it's the filter element from catchcans because I looked at the filter that came with my catch can and the strands are much thinner and smaller than the chunks in my buddies oil filter, so I'm leaning towards a low oil situation and something began chewing its self up. Oil pump gear ??? Lower bearings ?? Idk but it wasn't anything top end like cams flaking or rockers.. odd thing though ??? Youd THINK there would be sooooooome odd/bad engine noise , loss of power or hard starting. But NO BAD symptoms..
I been telling him TO GET HIS CAR HERE again asap so I can atleast pull out and check his new filter since we did an oil flush and change. And the amount of driving he does , hes probably got atleast another 1k since oil change so that should be plenty miles enough for me to check again..
once I'm able to 2x check , I will post back and let you guys know what I've found again..
Old Apr 8, 2024 | 09:47 AM
ok let us know. Might be left overs from an engine rebuild and they did not drain the pan?
Old Apr 10, 2024 | 05:21 AM
MiniManAdam
Community Builder
no unfortunately.. no major maintenance was done anytime soon and i had changed his oil about 5k miles and maybe a month TOPS befor and there was NOTHING in that oil change what so ever..
I keep telling him get it here and let me 2x check so hopefully he will be swinging through soon..
TaeWOW
Jul 3, 2023 08:02 AM
Coz3z3
Jun 8, 2022 08:15 AM
Brahmcts
Nov 13, 2017 10:40 AM
runswithsizzers
Aug 18, 2013 06:50 PM
jascooper
Oct 24, 2007 12:54 PM
