R50/53 Rear hatch seal
Old Feb 29, 2024 | 05:51 PM
Steezy's Avatar
Steezy
Rear hatch seal
Can someone help, i have tried 4 different seals and none seem to work and i cant continue this project until I fix this leak so my battery isn’t drowned in water. I have tried to put seals on the hatch door itself and still it leaks. I am starting to feel defeated… any ideas? I really don’t want to buy a brand new seal for $300 and it did not work and deal with the hassle of returns and refund. You can see a gap in the top left corner when looking inside out.. mini really screwed up on these seals…
Old Mar 1, 2024 | 07:01 AM
This is the main seal: Its like 160ish right now.
https://www.ecstuning.com/b-genuine-...t/51717132471/
Is the trunk lid grip handle seal leaking or do you have a sunroof with drain tubes that leak/clogged?
Old Mar 1, 2024 | 09:36 AM
cooper48's Avatar
cooper48
^^^ +1 on a leaking sunroof which is a common problem. Have you sprayed the hatch with a hose to either ID or eliminate it as the water source?
Old Mar 1, 2024 | 04:01 PM
Here2Go's Avatar
Here2Go
NAM Community Team
cooper48 makes a good point.
Also (as I've heard), the third brake light and antenna gasket are also a possible area to check for water intrusion.
Old Mar 1, 2024 | 06:31 PM
deepgrey's Avatar
deepgrey
I third the hose trick.
The gap you mentioned… Is that when the hatch is closed? If so, it may need adjustment, perhaps?
Old Mar 2, 2024 | 06:34 PM
Here2Go's Avatar
Here2Go
NAM Community Team
Good question regarding the gap that can be viewed from the inside out. I don't have my Bentley manual with me at the moment but I'm wondering if the hatch itself has any alignment capability(?)...
Old Mar 2, 2024 | 06:50 PM
deepgrey's Avatar
deepgrey
It does. I believe it’s adjustable at the hinges, buffers, and latch, IIRC. I seem to remember the body guys had a little trouble aligning mine to not leak.
Old Mar 2, 2024 | 07:41 PM
cooper48's Avatar
cooper48
^^^ What he said.
Gabe3
Jun 4, 2020 06:59 AM
Fishbreath
Feb 23, 2018 07:23 AM
CRC
Sep 17, 2017 08:59 AM
nickbee
Jan 20, 2011 11:03 AM
NaplesFL.MCS
Jul 1, 2008 07:41 PM
