R55 Another inoperable bard door / splitdoor issue
Old Dec 20, 2023 | 12:48 PM
johnrhopkins's Avatar
johnrhopkins
I just picked up a 2010 Clubman. The barn doors are stuck closed. I cannot open them by hand or with the remote. When pressing the unlock button on the remote, I can hear an actuator on the back driver's corner of the car, but that MIGHT be the gas cap releasing. I'm just not familiar enough with what is happening under its skin.
Pressing (or pressing and holding) the trunk button on either remote does nothing. No sounds at all from the car.
'So far, I've pulled out the four pins from inside the trunk area below the barn doors that hold in the plastic cover in place. I think I should be able to yank it out, but I'm afraid to break what I can't see.
That is where I am. Any suggestions?
Old May 7, 2024 | 10:03 AM
johnrhopkins
Weather is warming up so I'm back to sorting this out.
I found this diagram and it shows two locks. I'm wondering which one I'll need to address and more importantly, how to get access to them.
anyone?
Old May 9, 2024 | 10:41 PM
Toby B's Avatar
Toby B
https://www.realoem.com/bmw/enUS/sho...diagId=41_1816
this one?
you're going to want to attack #1 and #5. If you're lucky, you can push and pull on the door to relieve pressure from the latch
enough that it'll kick loose. If you are unlucky, it is stuck in 'double lock' mode.
If it's electrically stuck, there's anecdotal evidence from various BMW forums that you can get it to unlock by hotwiring it. I had no luck with that, as mine was mechanically stuck. Really physically broken.
If it's mechanically stuck, I have personal experience cutting a BMW lockset apart from inside the door, and it was... scarring.
All I got,
t
Old May 10, 2024 | 03:54 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
You should be able to get the door panel off with the door closed. There are push clips that hold them to the door. Once the panel is off, you can see the handles and latches.
Old Nov 6, 2024 | 07:49 AM
johnrhopkins
Okay, it has been a minute since I started trying to sort this out. Some other life events put this on the back burner. Now I'm back at it, and I'm stumped. I cannot get this trim panel off that I apparently need to remove to get to the latch. Thoughts?
Old Nov 6, 2024 | 08:06 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Have you gone through this thread?
https://www.northamericanmotoring.co...n-doors-2.html
Old Nov 6, 2024 | 08:12 AM
johnrhopkins
Yes, this is the post in there that I'm trying to follow: https://www.northamericanmotoring.co...ml#post3757911
ebrown0104
F54 :: Clubman Talk (2015+)
Sep 27, 2020 08:05 AM
rrcaniglia
Jan 18, 2017 02:24 PM
pjo1966
14
Jul 10, 2015 07:59 PM
bmrosen
R55 :: Clubman Talk (2008+)
28
May 15, 2015 11:42 AM
gzaos
Electrical
Dec 8, 2013 03:17 PM
