R50/53 Tricking the door
Old Jul 20, 2023 | 03:44 PM
Here2Go's Avatar
Here2Go
NAM Community Team
Tricking the door
Can anyone tell me how to "trick" my door/BCM into thinking that it is closed when it is actually open?
Is it possible?
My driver side door actuator seems to work when remotely using the FOB = Clunks when unlock/lock but doesn't actually/physically unlock the door. Only locks. Otherwise I've had to manually unlock using the key.
As we all know the Mini is uncomfortably cramped in there (unless you remove the front seat) while trying to work on the inside of the door with the door closed.
I need to be able to see inside the door (door card removed) while the door is open, in effort to view what the actuator is physically/mechanically doing while using the remote.
Part of my (alternate) plan would be to use the camera on my phone and mirror cast to my laptop. But temps are nearing 100° out here lately.
(I remember the good ole days where one could simply depress the button in between the door jamb in a somewhat limited way of "tricking" the car into thinking that the door was closed (so you could work on it)).
Is there a way to do this on a Mini?
Old Jul 21, 2023 | 03:46 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Just need to use a screwdriver to push the door latch to the closed position. I’ve done it on my R55. Learned it from the guy at the tint shop.
Happeee
Sep 15, 2017 11:22 AM
willy-mini
Feb 3, 2016 07:18 AM
TaylorL99
Mar 22, 2009 03:17 AM
PoktRokt
Dec 12, 2008 02:26 AM
MerchoMini
Nov 18, 2008 06:34 AM
