Engine malfunction reduced power
Old Jun 29, 2023 | 08:49 AM
elseed's Avatar
elseed
I recently had the timing service done by a non-dealership shop. I got the following codes today.
Ideas?
Old Jun 29, 2023 | 08:56 AM
2014 MC's Avatar
2014 MC
Looks like perhaps they didn't make all the electrical connections (after cat O2) and perhaps there is an issue with the actual timing they performed. Did you show this report to the shop doing the work?
Old Jun 29, 2023 | 09:44 AM
+1 ^^
Old Jun 29, 2023 | 11:19 AM
elseed's Avatar
elseed
Not yet. BTW, the shop also replaced the spark plugs.
Old Jun 29, 2023 | 11:33 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
My total uneducated guess... the shop reused the cam bolts, and the intake cam has slipped. Or, they didn't get the timing quite right.
The cam code and the charge pressure code are probably related. The charge pressure consequence code is probably due tot he cam angle being off. The O2 sensor code is probably just a coincidence.
Old Jun 30, 2023 | 08:39 AM
elseed's Avatar
elseed
Mini is in the shop. We'll see...
Old Jul 5, 2023 | 07:17 AM
elseed's Avatar
elseed
The shop diagnosed as bad Vanos Variable Valve Timing solenoids, will be replacing. Total cost about $1000.
Old Jul 5, 2023 | 08:00 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
At that price, hopefully it fixes it
Old Jul 7, 2023 | 06:58 AM
elseed's Avatar
elseed
I have driven my 2016 Countryman for a day now and no more codes so far since the shop replaced the Vanos solenoids.
They also performed a fuel pressure test and did not find any issue there.
Question, it has about 98,000 miles on it, what preventative maintenance does this board recommend that I can do to avoid another expensive trip to the shop?
This year, this car has had the following:
1. Thermostat housing and cross over pipe
2. Spark plugs
3. Timing belt service
4. Vanos valves
Keep motoring,
Tom
Old Aug 25, 2023 | 11:04 AM
elseed's Avatar
elseed
Well, the error codes are back again. Not the Vanos valves I guess. Here are the symptoms:
The error codes come in and the car goes into limp mode at almost the same time and distance from my house on the way out and only when starting cold.
I then clear the codes, and then the car drives fine for a week up to a month.
The it happens again.
No rough driving, it doesn't make any weird sounds, and the idle and acceleration is smooth.
Any ideas?
sripavan
Jan 16, 2021 07:08 AM
Thunderclasp
Jul 7, 2020 05:21 PM
ClubDumpster
May 23, 2016 09:54 AM
yyj3869
Jul 17, 2012 07:57 AM
JammyCooper
Nov 8, 2011 06:46 PM
