R56 wobbly window
Old Mar 24, 2023 | 05:17 PM
ahwest's Avatar
ahwest
wobbly window
Bought the mini with a wobbly window which i'm trying to fix right now.... I did search around and found some tutorial on youtube suggested tightening 4 torx bolts on the window regulator, that didn't fix it.... does anyone know how can i fix this problem?
Thanks in advance.
Old Mar 29, 2023 | 09:53 AM
Window is not tight on track or the little nut gear is not tight on window. Seal on regulator is worn.
https://www.realoem.com/bmw/enUS/sho...diagId=51_6223
https://www.ecstuning.com/Search/Sit...h/51332756083/ regulator picture driver side.
https://www.ecstuning.com/Search/Sit...h/51332756084/ passenger side.
Old Mar 29, 2023 | 01:30 PM
cooper48's Avatar
cooper48
^^^ What he said. Check the nylon gear. It's what holds the glass to the regulator. You can use a flat screwdriver and hammer to loosen and tighten it if you're careful (and also if it's similar to an R53)
Old Jul 29, 2023 | 11:06 AM
Ushangi's Avatar
Ushangi
Mfg Part # 51337342897
Old Jul 31, 2023 | 10:19 AM
Thats right here : https://www.ecstuning.com/Search/Sit...h/51337342897/
Old Jan 29, 2025 | 08:36 AM
MINI@PL's Avatar
MINI@PL
Hello Gyus,
Are those clips (#51337342897) doable to be replaced without removing the window regulator from the door?
I guess it wont be possible, but...?
Old Jan 29, 2025 | 10:36 AM
Hello,
You would have to take the inside door panel off an then reach up in the corner. Maybe possible but its tight.
https://www.realoem.com/bmw/enUS/sho...23#51337342897
Then that inside section.
https://www.northamericanmotoring.co...w-motor-431158
https://www.northamericanmotoring.co...tuck-shut.html
Old Jan 29, 2025 | 02:28 PM
MINI@PL's Avatar
MINI@PL
Will give it a try for sure!
Thanks a lot ECSTuning
Old Jan 30, 2025 | 08:08 AM
You are welcome
DrKirsch
Nov 4, 2023 01:34 AM
ghostwrench
Aug 1, 2020 09:19 PM
dL_EVO
Aug 7, 2009 09:28 AM
OutMotoring
Feb 22, 2005 08:37 PM
LizzyBobio
12
May 18, 2003 07:43 AM
