DME ? Which one ?
Old Aug 22, 2022 | 04:36 PM
colossal titan's Avatar
colossal titan
DME ? Which one ?
I’m not sure if this is how I post on here. First time on a forum. I have a 2009 Mini Cooper S convertible. I’ve smoked 2 #3 coil packs so far. It all started when I changed the leaking valve cover and forgot to hook the ground back up for the coil packs. I pretty sure I fried the DME. If I get a used one does it have to be for the exact model and year of mine? Will it need reprogrammed? If so is it something a normal mechanic can do? Thank you for your time
Old Aug 22, 2022 | 05:58 PM
shrevemini's Avatar
shrevemini
Top Answer: 1
Yes.
The issue is the DME stores your vin along with you mileage.
There are a couple site that will clone you DME an send you a remand one.
https://the-ecu-pro.com/garage/mini-...SAAEgJ6fPD_BwE
Old Aug 22, 2022 | 06:00 PM
shrevemini's Avatar
shrevemini
Top Answer: 1
Old Aug 22, 2022 | 09:17 PM
colossal titan
Thank you for the information.
colossal titan
Aug 22, 2022 11:38 AM
cooper48
Sep 14, 2018 09:40 AM
benben01
Dec 14, 2017 06:31 PM
matthewsphillips
Jun 15, 2016 08:25 PM
Jeff2491
How to
May 22, 2013 03:25 PM
