Drivers side axle will not budge
Old Nov 21, 2021 | 08:08 PM
Broo's Avatar
Broo
2006 R52 Aisin Automatic Trans 192,000 miles
This drivers side axle is the toughest Ive ever seen.
Ive tried:
prying until I thought the bar would break
Pulling it off with a slide hammer and a vice grip
air hammer
banging on the end of it with a sledge
NOTHING. Is this trans different? Is there a retaining ring like the manual trans?
ANY HELP OUT THERE? Need advice Fast!
Old Nov 22, 2021 | 05:30 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
I had a similar issue with my drivers axle, until I tried this tool:
Amazon Amazon
The automatic axle has a retaining clip
Old Nov 22, 2021 | 07:54 AM
Broo's Avatar
Broo
I tried to get a pickle fork in there, no room!
I had a mobile mechanic try to get it out, couldnt budge it. The axle seems a little wigglily now, I hope I didnt ruin something inside
Old Nov 22, 2021 | 07:59 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
That isn't a traditional pickle fork, its much thinner and designed specifically for popping axles. It comes with two forks, and one is tapered. The tapered one will pop that axles out like butter.
Old Nov 22, 2021 | 08:16 AM
Broo's Avatar
Broo
The frame is in the way. I dont think it will go in because theres not straight access, kind of tilted on a 2006 I could barely get a crow bar in there
Old Nov 27, 2021 | 08:49 PM
Broo's Avatar
Broo
Nik
The forks you recommended came today, as I suspected I couldnt get either one behind that dam cup portion thats still stuck in the tranny. Does it have to be in a certain gear? in Park? or?
the thing actually wiggles now, but wont budge. You must have a manual trans...........
Dam!
Old Dec 4, 2021 | 12:13 PM
Broo's Avatar
Broo
Drivers side axle wont budge
AS YOU CAN SEE, I PUT TREMENDOUS FORCE ON THIS THING. NOTHING! DOES IT HAVE TO BE IN A CERTAIN GEAR? THIS IS A AISIN AUTOMATIC
ANY HELP APPRECIATED
Old Dec 5, 2021 | 08:40 PM
ssoliman's Avatar
ssoliman
Should pop out with not much presure at all. There’s a ring on the axle that “snaps” in place.
Something is not right
the ring might be damaged
i wish I could help more
i got mine out with a pry bar
dont crack ur trans case
Old Dec 5, 2021 | 08:42 PM
ssoliman's Avatar
ssoliman
Plenty of vids on YouTube re this. Maybe some clues there
Old Dec 5, 2021 | 08:48 PM
Broo's Avatar
Broo
Yep, I realize that.
I believe the axle splines are "galled" onto the mating surface of the trans
Im going to try to punch it out from the passenger side
crossed fingers & prayer........
Old Dec 6, 2021 | 04:56 AM
DFTR's Avatar
DFTR
Careful with that idea. I think a member tried that about a month ago on here and fragged his differential.
jglover
Apr 23, 2018 06:24 AM
jglover
Apr 6, 2018 06:31 AM
srponies
Dec 6, 2013 01:09 PM
2003minicooper
Jan 7, 2013 03:11 PM
myla2003
Dec 11, 2009 08:14 AM
