R53 Stalling
Old Sep 4, 2021 | 11:37 AM
Mr_Stop's Avatar
Mr_Stop
R53 Stalling
The other night, my wife started our R53 and she said it was making a racket. I can get the car to start and it seems to run fine with the RPM's up. However, when the RPM's drop the car stalls. Also, if I put it into gear and try to move it, it stalls.
It shows a P0171 (system too lean) confirmed code and also a P0172 (system too rich) pending code. I could definitely smell changes in the exhaust. Is there a flowchart to diagnose the cause of the problem?
I have INPA along with a regular OBDII scanner. I'm trying to figure out where to download ISTA as well.
Old Sep 4, 2021 | 09:35 PM
ssoliman's Avatar
ssoliman
New t-map sensor fixed this for me. I had the same issue
i should add. If u go this route, go w stock sensor. Many issues reported with aftermarket…
one more add, what do your fuel trims look like in inpa?
Old Sep 5, 2021 | 03:13 PM
Mr_Stop's Avatar
Mr_Stop
Thanks for the tip. I got ISTA installed. It pointed to a bad pre cat O2 sensor. As I was running the test, I noticed that the car ran mostly fine until warmed up. Once it got close to operating temp, the car would stall unless I kept the RPM up.
I just picked up an O2 sensor, so we'll see if that solves the issue.
Old Sep 5, 2021 | 04:48 PM
ssoliman's Avatar
ssoliman
Good to hear let me know how it turns out
Old Sep 5, 2021 | 06:32 PM
Mr_Stop's Avatar
Mr_Stop
I got the new O2 sensor in, but it is still acting the same. I'm about to hit 100K, so I don't feel too bad about replacing it since it's recommended.
I ran a new test. I am now getting an error on the t-map sensor:
B60631 Intake air temperature/intake manifold pressure sensor 1
No fault can currently be found in the tested component group.
The intermittent fault may possibly be caused by a poor connection.
Check correct connection of plug connectors and line
I took out the tmap and it looks clean. All the connections and wires look fine, but need to remove the air box and have a closer look when it's light out.
Old Sep 5, 2021 | 06:54 PM
ssoliman's Avatar
ssoliman
R53 has tmap. R50 does not.
tmap is located in front of engine on the manifold
attached a pic
Old Sep 5, 2021 | 06:57 PM
ssoliman's Avatar
ssoliman
Try cleaning the plug and check the connector pins and all.
I had to replace mine…dollars to donuts, sir
Old Sep 5, 2021 | 07:07 PM
Mr_Stop's Avatar
Mr_Stop
I think I was looking at the wrong map sensor (the one about the thermostat). The t-map is in front of the engine, correct?
Replacement is likely, just can't get OEM on a holiday weekend...
Old Sep 5, 2021 | 11:36 PM
OhBoyHereWeAre's Avatar
OhBoyHereWeAre
Go to rockauto thats where i got myn 10k miles on it no problems
Old Sep 6, 2021 | 05:43 PM
ssoliman's Avatar
ssoliman
yes sir, front of engine. Use realoem.com to be sure u get the right part
i just got one from fcpeuro
Old Sep 7, 2021 | 05:15 AM
nd-photo.nl's Avatar
nd-photo.nl
Alternative site: https://mini.7zap.com/en/mini/r53/cooper+s/
Old Sep 7, 2021 | 02:33 PM
Mr_Stop's Avatar
Mr_Stop
I called Cincinnati Mini, hoping to find a T-Map sensor in stock locally. I'm constantly disappointed with this dealer. Nothing in stock and 10-13 days delivery for $190 something. This dealer never has anything in stock and marks parts up 30% over list. A couple of online Mini parts dealers list the same part for about $112, but I was unsure of the delivery time. fcpEuro and ECS had long lead times also. It's amazing that these are hard to come by for a seemingly frequent problem.
Fortunately @WayMotorWorks keeps them on hand for a fair price. I added a Cravenspeed dipstick to replace my broken one to the order. I'm hoping the sensor comes in soon as it's my wife's daily driver.
Old Sep 12, 2021 | 11:53 AM
Mr_Stop's Avatar
Mr_Stop
It was the T-Map sensor!!!!
Unfortunately, the new replacement hadn't arrived yet. However, an R53 landed in my local U-pull-and-pay yesterday. Grabbed it, cleaned it, installed it and everything is good with the world again!
Old Sep 13, 2021 | 11:38 AM
nd-photo.nl
Nice, good work!
Scott Warren
Dec 1, 2023 02:50 PM
TISGOD
R57 :: Cabrio Talk (2009+)
May 26, 2017 12:32 PM
pobudz
16
Jun 28, 2016 09:26 AM
Indie
12
Feb 24, 2015 05:33 PM
ClintTheMiniOwner
Aug 27, 2012 08:19 PM
