Bushing Upgrade
Bushing Upgrade
I’ll be doing a clutch job soon and wanted to get my front subframe bushings all swapped out as the car has 120,000 miles on her. Does anyone have a list of all the bushings I should be replacing?
I JUST got done with this job! I replaced the front control arm bushings and front sway bar bushings. You might also consider adding the lower engine mount inserts. No other bushings in the front of the car.
This is what I used:
https://www.waymotorworks.com/powerf...7-r58-r59.html
https://www.waymotorworks.com/powerf...unt-large.html
https://www.ecstuning.com/b-superpro...pf227624k~spr/
The biggest and most important is the front control arm bushings
We also do the front sway bar bushings with them as you will already have them unbolted
And doing the insert for the lower engine mount is a great mod as it will reduce engine rock and improve the shifting feel.
This is also another little insert bushing that fills in the gaps in the trans mount to reduce rocking even more.
Since you are doing a clutch job I would really encourage you to do the LSD if you are into performance at all as this will be the biggest gain in getting the HP to the ground and requires the trans to be removed to install.
https://www.waymotorworks.com/quaife...ferential.html
How many hours to replace control arm and sway bar bushings? Lower engine mount inserts - Can't say enough about these! Mine was complete toast, I thought I needed new suspension in a major way, when hitting bumps the entire car would move! With the inserts and new lower engine mount it is a night and day difference.
We just got in some more PSB bushings. https://www.ecstuning.com/b-psb-parts/v-mini/
Its another option.
I set to install these on my R58 jcw.
Its another option.
Rear is like 17mm , 18 for spot and JCW suspension
https://www.ecstuning.com/Mini-2008-...Rear/Bushings/
23.5 with https://www.realoem.com/bmw/enUS/sho...78#31356772844
https://www.ecstuning.com/Mini-2008-...way_Bar/Front/
dcantwell
Jul 22, 2015 09:48 AM
Suspension Can I upgrade to polyurethane bushings?
astroBlackMetallic_Mini
Suspension
Aug 15, 2013 08:19 PM
MC_Sean
Suspension
Jan 11, 2010 09:12 AM
Drivetrain Powerflex Bushings Break-In Time?
brianbreeze
Mar 21, 2008 05:44 AM
