R50/53 Ambient temp sensor?
Old Apr 1, 2021 | 09:48 AM
alconk's Avatar
alconk
Last couple days my outside temp has been reading 20 deg higher which also affects the ECU. Does this mean the sensor in front of the screen condenser is going bad?
Old Apr 1, 2021 | 12:07 PM
Ferrino's Avatar
Ferrino
I was told that this sensor has no impact on the ECU (i.e. simply for display outdoor temp). But the WMW page suggests it can regulate the AC system. Would love to know what it affects.
Old Apr 2, 2021 | 07:54 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Yes the ECU uses it to know the outside temperature to do it's calculations for timing and fuel.
Also the A/C uses it for it's calculations to know how hard to run the system. And if the sensor is failed the A/C won't come on at all as it defaults to think it's negative 40 degrees.
Old Apr 2, 2021 | 08:35 AM
alconk's Avatar
alconk
Yeah that what I thought about the ECU. Thanks
Old Apr 2, 2021 | 10:44 AM
nd-photo.nl's Avatar
nd-photo.nl
Interesting, didnt know that
Old Apr 2, 2021 | 12:08 PM
shrevemini's Avatar
shrevemini
Top Answer: 1
Is there a mounting clip for the sensor. Mine does not have anything to hold it on place.
Old Apr 2, 2021 | 12:44 PM
deepgrey's Avatar
deepgrey
There should be a clip on the bumper cover.
Old Apr 2, 2021 | 12:46 PM
shrevemini's Avatar
shrevemini
Top Answer: 1
Hmm I guess I will double check later. Thanks 👍
Old Apr 2, 2021 | 01:16 PM
deepgrey's Avatar
deepgrey
This is what it looks like. That photo is an R53, but the R50 is similar.
Old Apr 2, 2021 | 09:22 PM
adriancl's Avatar
adriancl
ECU don't use outside temp sensor signal.He don't care about it ,use the engine coolant temp and intake air temp from TMAP sensor.
Old Apr 2, 2021 | 10:00 PM
jk6672's Avatar
jk6672
I don’t have one at all. My dash does read -40 deg and my a/c works fine. Seeing the -40 never bothered me.
GTENA
Jul 27, 2019 12:44 PM
thulchatt
Jan 23, 2013 04:44 PM
xizor
Apr 25, 2007 03:15 PM
Bahamabart
Nov 10, 2005 11:49 AM
robertpick
Nov 19, 2002 09:28 AM
