Drivetrain from Hungary - perf chip
Old Nov 9, 2005 | 01:53 PM
Bahamabart's Avatar
Bahamabart
okay, i'm sure some will dam me to hell but i couldn't resist. Not being technical in this area what could this sucker be doing or perhaps better said imply that it does ? it taps in between the ecu and oxy sensor.
http://cgi.ebay.com/ebaymotors/20HP-...86731535QQrdZ1
Old Nov 9, 2005 | 04:28 PM
chows4us's Avatar
chows4us
Hmm. Welllll... if it were as good as he says, wouldnt he be like a millionare by now?
Dont all piggybacks tape before the ECU and just trick the CPU by feeding it false information.
I guess .... for anyone who buys it I got a Bridge to sell you too along with some 100 mpg carburaters
Old Nov 10, 2005 | 06:30 AM
andy@ross-tech.com's Avatar
andy@ross-tech.com
That's awesome. The O2 sensor is only used for closed-loop operation (idling, cruising, etc) in order to maintain the strict 14.7:1 A/F ratio required by the catalytic convertor to deliver the lowest emissions. When you actually want power to accelerate, you are going into open-loop where the oxygen sensor is ignored and the ECU uses its pre-determined lookup tables to deliver the correct amount of fuel for a given RPM and manifold pressure. So, if this device does anything at all (it may just be a fuse or a straight-through wire inside there), it would serve to make emissions worse at idle and cruise while yielding zero benefit to acceleration.
Old Nov 10, 2005 | 07:02 AM
Bahamabart's Avatar
Bahamabart
Thanks, thats what I wanted to try to understand or learn from this post - i.e. the role of the sensor.
Old Nov 10, 2005 | 07:04 AM
Bahamabart's Avatar
Bahamabart
Based on Andy's response, I assume this hungarian is well on his may to being a millionaire. My understanding is that they currently have a bridge in beta testing .
Old Nov 10, 2005 | 08:21 AM
norm03s's Avatar
norm03s
Their instructions indicate they are connecting to 02 sensor #2 (after the CAT). That sensor only monitors the efficiency of the CAT.
Result of this product = null
Does it come with stickers, LED's? might help some believe it does something.
Hey I'm Hungry
Old Nov 10, 2005 | 08:55 AM
little egg's Avatar
little egg
I am Hungarian, well descent. I was born and breed in the USA.
Be wary of these things, people in the "motherland" can be quite the shysters (sp?)
Old Nov 10, 2005 | 11:49 AM
Bahamabart's Avatar
Bahamabart
No intention of buying but wanted to "learn" what the logic was or if there even was one. I new if I posted, I would get one of the MINI-One-Kanobes to chime in and Andy did .
When the MINI-One-Kanobes are battling amongest themselves - you can really learn a thing or two
jeri534
Nov 6, 2015 01:40 PM
penguinplf
Oct 11, 2015 07:36 PM
tcjake
Sep 30, 2015 08:14 AM
Greezyman
Sep 22, 2015 06:02 AM
Systemlord
Sep 19, 2015 02:57 PM
