R52 HELP! Open R52 boot manually ??
Old Feb 20, 2021 | 06:59 AM
DiscoDave's Avatar
DiscoDave
I’m in a junkyard RIGHT NOW (Saturday morning) to get a roof of an R 52. I can’t get the trunk / boot open!
the fuse box along with the drivetrain is gone. I tried to hook up a battery anyway but there is no positive cable!
is there a manual release???
I watched a YouTube video that showed no release under the rear seat. I tried to remove the bottom of the rear seat to take a look but it will not budge!
I removed the boot trim and tried to jumper the wires but can’t get that to work.
im not above destroying the boot to get it open.
any help while I’m 1.5 hours from home in 20 something degrees??
Old Feb 20, 2021 | 07:46 AM
DiscoDave's Avatar
DiscoDave
Got it. It was ugly
Old Feb 20, 2021 | 07:55 AM
Mineeee's Avatar
Mineeee
Originally Posted by DiscoDave
Got it. It was ugly
Isnt it just a case of pulling the emergency release handle on the inside, or does that still require power to operate?
Old Feb 20, 2021 | 06:37 PM
Cobre's Avatar
Cobre
The glow-in-the-dark handle on the inside of the boot works with and without power. This is the correct way to do it.
Old Feb 21, 2021 | 07:57 AM
RudeJoe's Avatar
RudeJoe
For anyone reading this in the future there is a pull handle (bent metal rod) attached to the underside of the back seat. After removing it fish it down behind the right back seat back, hook the glow-in-the-dark handle and pull.
Old Feb 21, 2021 | 09:14 AM
RB-MINI's Avatar
RB-MINI
I wonder why they didn’t keep the original style under-seat cable and just add the glow handle in case someone was locked in the boot? It would be a pain to reach the release handle with the rod if the boot was full of stuff.
Old Feb 21, 2021 | 11:17 AM
RudeJoe's Avatar
RudeJoe
It is a pain. I’ve had to use it. But better than not having the option if you do shut the tailgate without the battery connected.
Old Feb 21, 2021 | 04:46 PM
DiscoDave's Avatar
DiscoDave
the bottom of the rear seat would not budge! I didn’t think a pull handle would be there but I was running out of options. This information above is no where that I could find. I looked for a long time!
There is one other way...
Old Feb 22, 2021 | 07:22 AM
DiscoDave's Avatar
DiscoDave
Right... Pull the handle in the boot that I can't get into...
Old Feb 22, 2021 | 07:25 AM
DiscoDave's Avatar
DiscoDave
For security. You can lock the boot with the roof down. With the pull handle under the back seat, the pull handle could easily be reached by a would-be thief. I guess they thought that thieves wouldn't be bothered to use the rod to fish for the handle. If your boot was full, you're screwed...
RudeJoe's Avatar
RudeJoe
So, did you get the top? How hard was it to get that off the car?
Old Feb 22, 2021 | 07:35 AM
DiscoDave's Avatar
DiscoDave
Yes I did, thanks for asking. It wasn't that hard once I figured out where to unbolt it. My challenges were more with getting to the attachment points under the interior rear side panels. These panels go down beside the rear seat bottom and I could NOT get that bottom out. I tried for some time, even using a prybar. It didn't help that the car had been sideswiped and the passenger door wouldn't open. One of the side panels had already been destroyed so I could get to one side. On the passenger side I had to drill about 50 holes in a pattern to form a panel l could remove to get to the attachment. Those panels are insanely strong!
There was 3 or 4 bolts/nuts at the forward attachment point, 3 bolts at the attachment point in the boot and then the various sensor wires, hydraulic cylinder hoses and leads. Getting it off the car by myself was a challenge but I finally got it.
Old Feb 22, 2021 | 09:10 AM
Mineeee's Avatar
Mineeee
When the roof is up you can reach down behind the rear seat past the parcel shelf. At least, thats how I did it. First time I hooked the seat back release and folded the rear seat down for access, next time I got the handle directly. It seems that the wires get frayed going through the rubber conduit so eventually its not uncommon for the external trunk release to fail as a result..
I does amuse me that they have an emergency release in case anyone is trapped in the trunk. Of a mini convertible. That's got to be a pretty small cross section of society that can be stuffed into a space about the size of a small sports bag. When I go kidnapping people I usually arrange to take my wifes car
Old Feb 22, 2021 | 09:58 AM
DiscoDave's Avatar
DiscoDave
Good to know that you can reach down through there. The roof was down on the car but the sunroof was closed! I'm not sure how it got in that configuration. I released the hydraulic pressure and was pushing it up and down during the removal but I didn't know the seats folded down until I got in the trunk! Newbie mistake!
Mei Lee
Oct 9, 2014 02:32 PM
Samysonary
Jan 24, 2010 07:20 AM
mystfynyou
Oct 28, 2007 07:02 PM
luluzapcat
Aug 1, 2006 03:54 PM
cra_bigal
Apr 28, 2006 07:38 PM
