Gremlins in the water
Old Jan 2, 2005 | 05:59 PM
cabmeister's Avatar
cabmeister
Strange thing on my way to pick my son up from the airport a couple of days ago.
Before leaving went through the normal checklist oil/water/fluid checks all ok.
got around 90 miles out and wanted to clear bug guts from windshield ,NO WATER comes out . So stopped and checked under the hood . All seemed fine water level was ok cap was on just noticed a trace of water on the plastic wheel cowl . In park I tried it again and still NO water but could hear the pump working . OH well carried on to the airport .
Got to the airport a little early (pulley and exhaust mods work huh)
tried again nothing this time with lights on and the light washers worked but still no screen wash .
Got the boy and got back to the car around 2 hrs later (airport security checks). got on board pulled out into traffic and tried again IT WORKED and has seemed to work ever since . Any one else gone through this ???
Old Jan 2, 2005 | 06:20 PM
911Fan's Avatar
911Fan
Maybe you ran it dry previously and it just needed some time to prime the pump...
Old Jan 2, 2005 | 07:15 PM
Ryephile's Avatar
Ryephile
Voo Doo MINI
We all have a bit of Voo Doo MINI in our own MINI
Old Jan 3, 2005 | 05:58 AM
Jdewey's Avatar
Jdewey
Window washers
If you let window washer solvent sit in the lines for a few days, the alchohol evaporates out but the water stays behind. The water will freeze in the lines when it gets cold outside. Parking a warm car allows the engine heat to thaw the lines.
This has happened to my other cars, but so far not my MINI.
Of course if you live in one of those boring areas where the seasons don't change this may not apply.
John
Old Jan 5, 2005 | 06:26 AM
mdsbrain's Avatar
mdsbrain
John
If you have the cold weather package on your mini isn't the fluid heated? I would figure this would break up and frozen fluid quickly.
Old Jan 5, 2005 | 06:51 AM
sndwave's Avatar
sndwave
Coordinator :: Gulf Coast & Panhandle MINIs
I do believe this is the same cabmeister that is also a member of Sunshine MINIs here in Florida and they have not had any weather cold enough down here to have anything freeze.
Old Jan 5, 2005 | 06:57 AM
rcase13's Avatar
rcase13
This is an easy one. The pulley mod has voided your washer bottle warrenty.
Old Jan 5, 2005 | 04:27 PM
cabmeister's Avatar
cabmeister
You know rcase I`m waiting for that one
Still no re-occurance of the problem
As Pat said no freezing weather here yet in Fl well not S Fl . as yet so its not that ,also the water bottle has never ever been even close to being empty .
The mystery continues
::: Keith
USNAE2
16
Jun 17, 2022 07:17 AM
PsychoRallye
21
Feb 17, 2019 06:08 AM
ian260
Mar 29, 2017 06:08 AM
vulkandino
Oct 31, 2015 08:29 PM
martinb
Oct 7, 2015 05:00 PM
