R50/53 Hood/Hatch open warning light
Old Jan 16, 2021 | 09:47 PM
ZigZagN's Avatar
ZigZagN
Well, after the warning light for the Hood/Hatch on my 2004 Cooper S came on and wouldn't go out, I decided to try to find the problem. I found an old thread where it was the switch on the hood latch, but disconnecting the wire from the switch didn't help, so I went to the hatch. First I couldn't get the inner panel off as I didn't have the right tool to pop the clips after removing the screws, so I took the pc above the license plate loose and again, could not see how to get the wire plug loose from the panel and gave up for the time being. So after putting it back and closing the hatch, now the light has gone off. So, typical, I messed with it without finding the problem only to have the problem go away. So, I'm sure it will be back.
Old Jan 17, 2021 | 09:14 AM
MiniManAdam's Avatar
MiniManAdam
Community Builder
Mine was always on when I bought my car , I needed to adjust the trunk stop so that it closed correctly to trip the sensor.. you may want to look into that
Old Jan 17, 2021 | 03:35 PM
ZigZagN's Avatar
ZigZagN
What is the trunk stop?
Old Jan 17, 2021 | 03:44 PM
MiniManAdam
Community Builder
the latch mechanism, it can be loosened and slid around to adjust the depth in which the trunk will latch shut, alot of times over time it gets knocked back and just needs to be slid forward a little
if you'd like I can take a pic of what I mean to better explain
Old Jan 17, 2021 | 07:44 PM
ssoliman's Avatar
ssoliman
there is also a process for adjusting the hatch in the Bentley iirc
Old Aug 3, 2024 | 10:46 PM
furia's Avatar
furia
Same problem
I have the same problem, also having the broken lock I replaced it but the light is always on, it's annoying how can I turn it off? what is the meaning and can I disconnect it or make an electrical bridge to trick it? thanks
Old Aug 4, 2024 | 12:23 PM
Here2Go's Avatar
Here2Go
NAM Community Team
Interesting.
A couple of months ago my hood/hatch light came on while I was out on a fun little roadtrip.
After a few unsuccessful attempts trying to determine whether the hood or hatch to be the cause. I finally decided that given the amount of dirt and grease in the rear hatch latch catch was most likely at fault.
I spotted and pulled into an auto parts store and bought a can of degreaser and carb/brake cleaner. I liberally sprayed down the dirt/grime in catch with the cleaners which resolved the issue.
No open hood/hatch dash light!
Old Aug 4, 2024 | 12:30 PM
furia's Avatar
furia
Originally Posted by Here2Go
Interesting.
thanks I'll try but having changed the whole lock I don't think it's that
Old Aug 4, 2024 | 05:32 PM
Here2Go's Avatar
Here2Go
NAM Community Team
With you having replaced the latch with a new one - you're probably right. Cleaning the new one probably won't help.
Mine was just about as dirty as your old one pictured above. The latch was secure (locked), but I guess I was lucky that the grime was impeding a good electrical connection and nothing mechanically wrong.
I hope you can get it sorted out.
Old Aug 5, 2024 | 12:01 AM
furia's Avatar
furia
the photo is of the new lock although actually used, however I sprayed the spray on both the front and rear locks but unfortunately the light does not go out
martinb
Feb 20, 2023 03:46 PM
Rgallic
Oct 22, 2017 05:44 PM
m3456y
Aug 27, 2008 08:11 PM
cooperchan
Feb 23, 2008 02:22 PM
EmCeeEss
May 25, 2004 07:29 PM
