Multiple codes
Old Dec 10, 2020 | 04:16 AM
glitter_girl's Avatar
glitter_girl
Multiple codes
So I have having issues with the wife's 02 S.
we just finished doing. an engine swap lwmt to start the car and when I turned the key and all the power went off,checked the battery ground it was loose. Got the fired up and it ran like crap and the rpm was all over the place. Could the ecm have fried ?
Codes I am getting
P1689
P0638
P1125
P1109
P1242
I will be replacing one of the sensors today and see if the code come back. If the code comes back on after I replace the sensor. What could I be looking at. ECM?
Old Dec 10, 2020 | 08:19 AM
jjcsnlynn's Avatar
jjcsnlynn
If you did an engine swap, I am assuming that you cleared all the previous codes and these are recent, active codes. These will stay in the ecu even with battery removal.
Old Dec 10, 2020 | 01:15 PM
ssoliman's Avatar
ssoliman
also load test battery be sure it is good...bad battery may cause many codes as some have described
impakt
Jul 23, 2021 05:11 PM
2014 MC
May 8, 2019 11:53 AM
Mini-Solus
May 7, 2019 05:40 PM
ColoCoug
Sep 8, 2017 03:12 PM
Drama_Llama
Aug 25, 2007 11:49 AM
