OEM Brake Caliper Question
Old Nov 22, 2020 | 02:24 PM
Sean Medley's Avatar
Sean Medley
I cannot get the piston to compress on my rear calipers and am wondering if it is a function of age. If I order new OEM Mini calipers, would they come pre-compressed? With the calipers at 17+ Years old, it seems it is time, but it is plausible that it is user error as none of the Schwaben adapters with the kit I ordered from ECS are fitting.
Old Nov 22, 2020 | 03:42 PM
Eurothrasher's Avatar
Eurothrasher
Piston ( for rear ) needs to rotate while being compressed correct ?
Old Nov 22, 2020 | 03:46 PM
Da_Ghost's Avatar
Da_Ghost
Yup.
Old Nov 22, 2020 | 04:13 PM
Eurothrasher
In a "pinch" if you have a Large "C-clamp", that can work if you don't have proper tool to rotate it while being compressed.....
Old Nov 22, 2020 | 04:15 PM
Eurothrasher
https://www.ecstuning.com/b-schwaben...ces/pbk-11pcs/
Old Nov 22, 2020 | 07:01 PM
Sean Medley
I have that exact Schwaben tool and none of the adapters seat into my piston. I was hoping that if I just bought new calipers the piston would be seated.
Old Nov 22, 2020 | 07:58 PM
Racingguy04's Avatar
Racingguy04
It takes some muscle, but I compress my rears with a pair of needle nose pliers stuck in the depressions on the piston. I just push and twist.
Old Nov 23, 2020 | 05:10 AM
Eurothrasher
Kit is for MINI....with modification for pre-2007.
**MINI - Rear brake cylinder holes on select MINIs with need slightly enlarged, you will then use the standard one already on the end of the tool.***
Old Nov 23, 2020 | 05:14 AM
Eurothrasher
Or, there is this one ready to go: Approximately US $31.22
https://www.ebay.com/itm/Laser-3940-...oAAMXQVT9S3lQJ
Old Nov 23, 2020 | 06:06 AM
Sean Medley
I’d not seen any instructions at all related to enlarging the holes. I’ll give that a shot.
jblow
Tires, Wheels, & Brakes
Jan 15, 2012 04:43 PM
IzzyG
Mar 9, 2009 11:12 PM
earlrabbit
Oct 8, 2007 12:47 PM
billblegen
Jan 9, 2007 04:31 PM
AlpinaM3
Nov 27, 2006 09:38 PM
