Broken HVAC blend door actuator?
Old Nov 10, 2020 | 09:34 AM
imaslowdriver's Avatar
imaslowdriver
So I've been having some weird issues with the automatic HVAC system in my 05 cooper S. The AC works great and the heater used to work great until a couple weeks ago. I ran diagnostics and found no codes. After the heater stopped working, I notice when I slam on the brakes hard, the air coming out of the vents switches to hot air, regardless of whether the temperature was set to a colder or hotter temperature.
This makes me suspect it's the blend door actuator because of how it switches to heat when I hit the brakes hard. Maybe it's loose somehow and can't stay in the heat position? Also, very occasionally, I'll turn the heater on and it works for two seconds, but then goes back to cold air. Am I right in suspecting its the blend door actuator?
Old Nov 11, 2020 | 09:58 AM
imaslowdriver
bump
Old Nov 11, 2020 | 02:49 PM
ssoliman's Avatar
ssoliman
Having a similar issue. What did you use to check for codes?
Old Nov 11, 2020 | 02:54 PM
ssoliman's Avatar
ssoliman
I’ll dig up the code I have it somewhere.
My 2006 r53 has no heat. I think it’s the actuator to the blend door / flap. Says it has a short to ground iirc.
Old Nov 11, 2020 | 04:04 PM
imaslowdriver
Really? It gave you a code? I just used the diagnostics system built into the automatic AC system.
Old Nov 12, 2020 | 05:33 PM
ssoliman's Avatar
ssoliman
Here is my thread
https://www.northamericanmotoring.co...t-working.html
inpa gives a code and calls it the “engine temperature mixing flap” I think.
on the ac control unit I have “FF” “01”. Forgetting what that is now. Need to look it up again.
as far as I can tell the actuator is under the dash on the right side. Might be able to access by removing the glove box, might have to take out the dash, I don’t know yet. Really hope it’s the first
Old Nov 12, 2020 | 05:39 PM
ssoliman's Avatar
ssoliman
I will update when I get more. Please do the same
Old Nov 13, 2020 | 09:38 AM
imaslowdriver
Yup, will do, probably going to call a shop today because it's freezing down here and hopefully have them diagnose the issue.
Old Nov 17, 2020 | 07:22 PM
imaslowdriver
Here's an update: found the issue. The blend door was infact the problem, and it had popped off its hinges because it snagged on a wire for my dashcam, so it wasn't turning like it was supposed to.
Old Dec 13, 2020 | 07:08 PM
Dan_in_WA's Avatar
Dan_in_WA
Found this video while researching a similar problem.
I’m starting to think about making a Sticky thread that people can quickly find useful videos like this to troubleshoot their own A/C problems.
Old May 30, 2022 | 05:23 PM
Grand-Cayman's Avatar
Grand-Cayman
I am having the same issue. Have the glove box out. Where is the blend door actuator? I see where the hot-cold dial/switch cable moves the arm in the passenger side footwell..
Old Jul 5, 2023 | 09:37 PM
MiniModder's Avatar
MiniModder
Did you bother taking any PICTURES??
Old May 30, 2024 | 04:40 AM
Gagroot's Avatar
Gagroot
Your observation about the air switching to hot when you brake hard is intriguing. It could indeed point to a faulty blend door actuator. Those little parts can cause big headaches! As for the intermittent heating, it's another classic symptom. If you're up for it, tackling the repair yourself could be rewarding. But if you prefer expert hands, consider reaching out to Repair Near Me. They fixed up my AC last summer, and I was back to cool breezes in no time. Best of luck getting to the bottom of the issue!
mkov608
Jul 29, 2019 10:59 AM
demesaroderick@yahoo.com
May 20, 2019 10:00 PM
bbqbyrds
Jan 11, 2017 01:47 PM
4GAZM
Jan 30, 2009 11:01 AM
4GAZM
Nov 17, 2008 08:56 PM
