JCW Garage Interested in John Cooper Works (JCW) parts for your 1st Generation MINI? This is where JCW upgrades and accessories for the Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs are discussed.
Dealer or Factory JCW
Old Nov 6, 2020 | 12:34 PM
Jonny's Avatar
Jonny
Trying to figure out the easiest ways to decipher if my 2006 JCW is dealer installed or factory. Even though it doesn’t really matter, so my build sheet says 3AL not 3SAL. Is this one way to figure it out, what are the other ways?
Old Nov 6, 2020 | 01:18 PM
RB-MINI's Avatar
RB-MINI
I think 3AL and 3SAL are both valid and the 3 or 4 character code difference depends on which VIN decoder you use. Same with the LSD 2TA and it’s 4 character counterpart which I don’t remember now. If your VIN has both of those codes it should be a Factory JCW.
Other quick checks would be actual JCW front calipers and an LSD. Real JCW calipers have a thick curved cross bar that follows the hub, and R56 calipers have a thin straight bar.
I’ve read conflicting posts on whether you can tell if you have one by jacking up the front and rotating one wheel to see how the other spins, but maybe someone else knows a way to confirm an LSD without opening up the transmission.
Old Nov 6, 2020 | 03:29 PM
MINIAC's Avatar
MINIAC
The option code for the JCW Package is 3AL, although the code may be listed preceded by an S and followed by an A (S3ALA).
File Type: pdf
Old Nov 7, 2020 | 04:30 PM
JackMac's Avatar
JackMac
One easy way is to use this VIN decoder: https://www.mdecoder.com/
If it’s on there, it’s factory installed. Note - you only get one use per day, so get screen shots
biggripper
Factory JCW Talk (2009+)
16
Oct 20, 2011 07:22 PM
JimmyC(KY)
26
Jan 30, 2011 12:32 PM
paradoxmonkey
Dec 30, 2009 09:16 PM
Lippy
Oct 6, 2008 08:22 PM
Drsms22
May 27, 2007 12:17 PM
