Fault code C0700
Old Oct 20, 2020 | 06:46 PM
MINI_42's Avatar
MINI_42
Fault code C0700
I have a 2006 R53 manual transmission, and a Bentley manual (for 2007 - 2011), and a Haynes manual for my 2006 model. I have several codes right now that I can't clear with the Schwaben that I got from ECS Tuning. I'm getting the following codes that I cannot clear:
C0700
C0304
P0300 (multiple cylinder misfire)
And Service Engine Soon light
Does anyone know what they may be? My manuals are not offering up anything on the 'C' codes and google searches are wild - anywhere from cat converter to fuel rail, 02 sensors and MAF sensor.
Some background: I had a rough idle and while diagnosing it with the engine running, I found the coil pack was not firing cylinders 2 & 3. Installed a new coil pack, same issue, then traced the coil supply side and found wire damage, which I repaired and it runs absolutely fine....other than the SES light and the codes listed.
I did let it idle for quite a long time, like 15 minutes or so, while I was yanking ignition wires looking for arcs and sparks...is it plausible that the fuel that went into cylinders 2 & 3 without being burnt off has lodged in the cat converter and causing the SES light? That's speculation of course, and would love to know the code definitions.
Can anyone point me to an online code list? The manuals I have are pretty good with their listings, but obviously are lacking a tad.
Thanks folks
Mike
Old Oct 21, 2020 | 12:55 PM
Kazukins's Avatar
Kazukins
From what I have researched, the c0700 code refers to a Mass Air Flow Sensor for BMW's. In the case of Mini, the Mass Air Flow Sensor is actually a MAP Sensor. It is possible this needs to be replaced as well as checking for any vacuum leaks and air filter. The other is possible head gasket failure which would allow more air or oil in the engine and thus misfire. I don't know why these codes are not releasing if you stated you fixed the issue. Perhaps another type of code scanner would do the trick but I don't know of any. As for a code list, there is an extensive list here https://new.minimania.com/Mini_Cooper_Gen_II_OBDII_Powertrain_Codes
It doesn't list the codes that start with C but it does give most of the P codes.
Old Oct 21, 2020 | 06:43 PM
MINI_42's Avatar
MINI_42
Thanks mate. Come to think of it, I did see that the 06 models have MAP not MAF. I checked tonight for disturbed vacuum lines, couldn't find anything. Started it up to run the Schwaben on it again and the SES light is now out. Maybe it is one of those times where if it doesn't detect the same fault condition after driving, the light goes out? I don't know where I read that before but wish I could remember.
So now the C0700 is stored as a pending code. Maybe it's on the way out of the ECU? The other two are still existing DTCs.
And the carpets are wet from the rain. Now I'll be looking for where the water comes in. Maybe the C codes, are Chassis, water ingress? Thanks for the link to the mini mania site, that's a good reference.
Mike
Old Oct 21, 2020 | 07:54 PM
ssoliman's Avatar
ssoliman
You may get more specific codes for inpa
Old Oct 22, 2020 | 02:48 PM
Kazukins's Avatar
Kazukins
So glad to know that the problem fixed itself. Yes, I do believe codes are still stored in the ECU and have an occasional habit of popping up again if at the slightest change. It takes a couple if not several runs before the ECU decides to ignore them. As for the wet carpets, if it is not related to a drivers/ passenger side window not sealing properly then you may be looking at the drain plug under the ABS motor section as well as the lower windshield trim. The plastic clips holding the trim are prone to becoming brittle and breaking so that is leaves a gap in between the trim and bonnet. There is a channel that the trim sits in and if it is not sealed, it will allow water to just flow into and around the firewall. Thus, wet carpets.I know this from experience as I have yet to replace the trim on mine. It is currently taped with blue painters tape to keep some water out.
Old Oct 25, 2020 | 12:40 AM
MINI_42's Avatar
MINI_42
Thank you for that information! I was wondering if it was the windshield trim; I need to get out there and poke around to see if I can figure out a source of water entry. I also have an 09 Clubman and the spare tire chamber was filling up with water...I just fixed that yesterday. The R53 scares me a bit more because it's probably coming in behind the dash somewhere and I don't want to pull the dash apart. Heading to Florida tomorrow, when I get home I'll have a look. Thanks again!
Old Oct 25, 2020 | 12:43 AM
MINI_42's Avatar
MINI_42
Thank you, I don't have a windows computer; I don't think it will work on my mac.
Old Oct 26, 2020 | 12:07 PM
ssoliman's Avatar
ssoliman
I have it installed on an older Mac (usb port) with boot camp. Works well
Old Oct 27, 2020 | 11:09 AM
nd-photo.nl's Avatar
nd-photo.nl
I have INPA running on my Macbook Air with VMware Fusion running Windows7
Old Oct 28, 2020 | 06:23 AM
MINI_42's Avatar
MINI_42
Thanks guys. For those of you with INPA, is there a specific version you use? I see there are 2 (in my limited search). I have an old Mac with windows XP on it (that I'd forgotten about); I will dig it out and see if I can make it work.
I appreciate the additional info.
Mike
Old Oct 28, 2020 | 09:09 AM
ssoliman's Avatar
ssoliman
I have a post titled “inpa” with all details of my install. Hope it helps you
Old Sep 4, 2022 | 07:21 PM
The Devil Z's Avatar
The Devil Z
Likely fuel pump. Get a dw65
Old Sep 7, 2022 | 11:45 AM
" I have several codes right now that I can't clear with the Schwaben that I got from ECS Tuning. I'm getting the following codes that I cannot clear:
C0700
C0304
P0300 (multiple cylinder misfire)"
When they cannot be cleared that means they are current, it will clear all codes unless they are permanent.
sliderhd
Jun 4, 2015 09:01 AM
Nightfall8403
Jul 23, 2014 04:56 PM
Ramie
Jun 25, 2013 10:42 AM
00m.u037
Aug 30, 2012 07:18 PM
oh2winlemans
Jul 15, 2012 04:16 PM
