R50/53 Cylinder 3 still misfiring
Old Oct 13, 2020 | 05:13 PM
GreenMiniEthan's Avatar
GreenMiniEthan
My check engine light and stability control light came on because of a misfire on cylinder 3. I have replaced the fuel injector, spark plug and wires and nothing has been fixed. Does anyone know what I should try next?
Old Oct 13, 2020 | 05:33 PM
JAB 67's Avatar
JAB 67
Check the cylinder 3 contact point on the coil pack. As I recall it is prone to corrosion which can cause misfire. If corroded, replace the pack.
Old Oct 13, 2020 | 05:39 PM
GreenMiniEthan
Thanks for the tip. Will do that soon and then update.
Old Oct 14, 2020 | 06:28 AM
steve05ram360's Avatar
steve05ram360
That is interesting... I just cleaned that contact point on the MSD coil I have... wonder why it is on the #3 plug...
Old Oct 14, 2020 | 11:03 AM
MVPeters's Avatar
MVPeters
One of life's MINI mysteries - it's always the #3 contact that corrodes - nobody knows why!
A little dielectric grease will help.
Old Oct 14, 2020 | 12:21 PM
steve05ram360
Wow that is bizarre... wonder if its firing order related...
Old Oct 14, 2020 | 12:24 PM
nd-photo.nl's Avatar
nd-photo.nl
Yep, I also read about this. Was able to find this picture:
https://www.northamericanmotoring.co...ium-plugs.html
Old Oct 15, 2020 | 05:36 PM
GreenMiniEthan
I inspected the plugs and found that they both look clean. In the picture below is the contact points on the coil pack. The one on the right is for cylinder 3 (the bad cylinder)
Old Oct 15, 2020 | 11:46 PM
nd-photo.nl
That looks quite alright. You are missing the heatshield on the engine side?
I think the only way to move forward is to try another coil
Stephen Rivers
Feb 21, 2020 07:44 PM
Chet1185
Oct 8, 2018 06:12 AM
Dan Kremer
Aug 10, 2017 07:21 PM
kazzy1313
Dec 18, 2015 06:02 PM
JCampos
May 18, 2009 11:58 AM
