Harmon Kardon under seat speakers
Old Jul 24, 2020 | 12:19 PM
KindaCoolDad's Avatar
KindaCoolDad
I just picked up a 2017 Countryman All4 S today. Fantastic fun so far, but I’m worried about the under seat speakers. I have a Harmon Kardon system but it doesn’t feel or sound like they’re producing anything at all. Do they serve as subwoofers? Because if so they have nothing going on for me right now.
Old Jul 24, 2020 | 02:24 PM
NBCGLX's Avatar
NBCGLX
The h/k system is pretty good for the overall cost. You should definitely hear/feel some good bass coming from the underseat woofers. I know this sounds like a dumb question, but did you turn the bass up at all? In my F57, I only have the bass turned up 2 notches and it's more than plenty of bass in the car, even with the top down (though of course I need to turn the volume up with the top down).
Old Jul 24, 2020 | 03:59 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
They are not sub-woofers and won't produce that true SW thump.
Old Jul 24, 2020 | 05:04 PM
madmix's Avatar
madmix
play something with a decent bass line, then put your had on the grill underneath the seat. They are subs, but crossover makes a big difference. I have the HK subs under my seat and after adding a better crossover things got better.
Old Jul 24, 2020 | 10:34 PM
KindaCoolDad
I put the bass all the way up and definitely tried some bass tracks - didn’t feel anything with my hands against the grill. In fact, to get any decent bass in the mid speakers, I have to adjust the bass nearly all the way up. Strange because it seems all the other speakers work fine. I also noticed I have to turn the overall volume nearly halfway up for the music to be at a decent level. I can't hear barely anything when it's at 25% or lower volume.
I'm beginning to think it may be an amp issue.
Old Jul 25, 2020 | 07:19 AM
2017All4's Avatar
2017All4
Super Moderator
The underseat speakers are designed to add bass, though they are not true sub-woofers capable of serious thump.
There are aftermarket solutions, including additional amplification and better third-party speakers. Due to limited space under the front seats, if you want a lot of bass, mods and relocation of subs may be your solution.
But FIRST, you gotta determine if what you now have is working properly. You should be able to hear/feel something coming from those OEM HK speakers.
Old Jul 25, 2020 | 07:21 AM
KindaCoolDad
I pulled off the under seat grills and placed my hand on the speaker itself. Nothing at all. Definitely not getting anything from them.
Old Jul 25, 2020 | 07:25 AM
2017All4's Avatar
2017All4
Super Moderator
If still under warranty, have the dealer take a look.
Old Jul 26, 2020 | 06:58 AM
NBCGLX's Avatar
NBCGLX
Something’s not right. No, they’re not subwoofers, but they are woofers and throw a decent amount of bass. I rarely turn the volume up past about 25% (maybe 50% if the top is down and I’m really jamming) and the bass coming from the woofers can easily be felt and I only have the bass turned up 2 notches from center.
Old Jul 26, 2020 | 07:31 PM
madmix's Avatar
madmix
here is a diagram that should help you troubleshoot things further. HK is a three way system so crossover is done on the amp. Check to make sure woofers ( sorry apparently people are using the literal definition of subwoofer producing frequencies below 30 hz) are plugged in. If they are could be a problem with the amp. There are a couple of other things going on in between but nothing that should stop the signal completely to both.
https://www.newtis.info/tisv2/a/en/f...ers/1VnXpLKQEQ
Old Aug 25, 2020 | 06:27 AM
KindaCoolDad
It was indeed the amp. I picked up a used one online for a song. Whole speaker system came life. Louder, richer, fuller, AND the under seat subs work!
Huzzah!
Old Aug 25, 2020 | 06:40 AM
madmix's Avatar
madmix
good I am glad you got it fixed. Should sound much better now.
KindaCoolDad
Aug 24, 2021 06:34 AM
hotknife
Sep 9, 2015 10:45 AM
rennwerkes
Jun 18, 2013 07:27 PM
rsosborn
Aug 31, 2011 05:02 PM
fixman2k
Mar 17, 2010 11:52 AM
