[QUOTE=bruski83;4541572]if this works with my 04 cooper s 6speed, I will take it right now. let me know if you know.
Check this thread - it's do-able, but it's not plug and play. https://www.northamericanmotoring.co...hopefully.html
Not sure if this will work with a pre-facelift car. The chrono pkg was optional on 2005-2006 cars and not sure if it plug up with the center
speedo or not in earlier cars :(
It will work. I have it in my 07/04 pre facelift R50. You will have to get the center gauge reprogram to match vin an mileage. An a few other things on the kombi in the center gauge. Since it is a pre facelift the oil temp an pressure will not work. You will need a post DME programmed to you car for it to work. I'm waiting on my reprogrammed DME to arrive so I can install . So I can get the oil gauges to work.
Here is a vid.
I'd love to swap my NAV setup for a Chrono setup in my 2006. I'll have to do my research. I might be coming through your area in a few weeks, if you've still got it I might try to get it from you.
